Edward_Roumoulian
Jun 21, 2023 8:28 AM UTC
Prototyping with transparent videos
Whatever I try, I can’t seem to work with .mov or .webm videos with transparent background on Figma. Whenever I upload them, I get a black background. Am I doing something wrong? Or is there a workaround for this?
    kingkong
    Jun 26, 2025 6:33 AM UTC
    还有序列帧动画也可以,很麻烦把所有的组件 串联起来 制作变体播放~luminace 是完美方案
    smore_erik
    Aug 26, 2025 10:29 PM UTC
    I’m running into this issue as well. Kind of sad that this hasn’t received any attention.
    Garry Turner
    Sep 17, 2025 4:45 PM UTC
    Extremely frustrating that Figma still doesn’t support transparent videos. Having said that, here’s a neat workaround for those with the compositing chops to do so in something like After Effects.
    1. Export a compatible video with no Alpha, such as h264.
    2. Create a black & white luma matte based on the alpha of your main footage. In AE for example, drag your main comp onto the new comp button; make a new white solid and use your main comp as the track matte layer (alpha); and then create a black solid for the background layer. Again, export this new comp with no Alpha, using h264.
    3. Drag both videos into Figma and align them on top of each other, with the Luma matte on the bottom. With both selected, right-click and “use as mask”.
    4. Go into the Mask group, select the luma matte video layer and set the Mask option on the right to “Luminance”.
    Hope this helps some folks in the meantime.
    You, sir… are a gentleman and a scholar for figuring out this bit of a hack. Thank you.
    Pretty impressed with the solution. Only little hic is when the video is a loop then eventually the mask video does not sync with the main video.
    Garry Turner
    Sep 18, 2025 8:31 AM UTC
    Dear Figma team, please consider enabling support for transparent videos. It would open up incredible possibilities for motion design and seamless UI integration. We’re dreaming of it—make it happen!
    SLT-UX
    Oct 21, 2025 6:15 AM UTC
    I did some investigating and discovered that when you create a fresh transparent video file (hevc mp4 at least, maybe vp9 webm too) transparency works perfectly in Edit mode and Prototype mode.
    Transparency gets lost if you:
    • Duplicate the layer (duplicate will lose transparency)
    • Change selection to a duplicate that is broken, then go back selecting previously working layer
    • Likely other actions
    Things tried to revive transparency, but failed:
    • Reloading tab
    • Deleting video layer and dragging video file again into the same Figma file
    • Creating a fresh new Draft file and dragging the video there (if transparency for this file was lost previously, even the first drag is instantly black)
    • Renaming the file in OS and dragging that into Figma (agian instantly black)
    • Switching between desktop app and browser (Chrome, Safari, Firefox)
    Once transparency is lost - can’t revive it.
    Feels like Figma is trying to cache videos or something, getting rid of transparency in the process. Even though it is already fully capable of displaying them properly.
    Since the capability is already there, this is likely to be low effort fix for dev team at Figma.
    Another buggy behavior, possibly related (if caching is the cause of all this):
    After I drag a second video into Figma, it’s layer name will display incorrect file name, showing the file name of the very first video that was ever dragged into that Figma file. Even if that layer was already deleted.
    In the above image I first:
    1. Dragged CCV Logo Outro - White - Transparent - hevc-safari.mp4
    2. Deleted it’s layer CCV Logo Outro - White - Transparent - hevc-safari
    3. Dragged CCV Logo Outro - White - Transparent - vp9-chrome.webm
    The new layer got name CCV Logo Outro - White - Transparent - hevc-safari 1 instead of ...vp9-chrome
    Notice the 1 as well. Figma thought it already had an exact copy, so it appended a 1.
    ​@Figma_Support please take a look at the above as it does much of the investigative work involved in determining the problem.
    It’s essentially a bug, as videos with alpha transparency do render and play with the transparency - but only the first time. Then the black background is applied.
    Being able to make use of videos with alpha transparency (which are becoming more and more used), unlocks a ton of new prototyping possibilities that aren’t possible today (at least in Figma.)
    Team Figma: Please consider fixing this bug if you want to delight your users. You won’t regret it.
    Tagging you ​@Tom Reem as you seem to be responding to us users here (thank you for that).
    Ed111
    Nov 19, 2025 8:46 AM UTC
    This feature has been waiting for 2 years now still no resolve??? How the hell
    Mario_Borg
    Jan 5, 2026 11:46 AM UTC
    Any updates on this issue?
    yipooo
    Jan 22, 2026 3:02 AM UTC
    https://www.figma.com/community/plugin/1593248715946421554/alpha-video-importer
    I ran into the same issue and made a plugin as a workaround. It converts a transparent MOV into two MP4s (color + black-and-white alpha) and stacks them to simulate transparency.
    Note: Figma seems to have upload limits for free accounts, so layers may not show up properly for free users.
    Mo Hady
    Feb 13, 2026 12:05 PM UTC
    Good plugin but doesn’t work if the two videos generated are looped.
    The two generated video only play for their video duration. but if i made them loop they only play once anyway. can you help understand why?
    yipooo
    Feb 13, 2026 3:49 PM UTC
    Hi Mo Hady, thank you so much for using the plugin and providing this feedback! Regarding the looping issue, the plugin's logic is actually designed to enable the "Loop" property for both video layers by default upon generation. To help me analyze why it's not working as expected in your case, would you mind sharing a sample Figma file link (with view or edit access) where this issue occurs? This will allow me to investigate the synchronization and looping behavior directly. Feel free to send it to me via private message if you prefer!
