Edward_Roumoulian
Jun 21, 2023 8:28 AM UTC
Prototyping with transparent videos
Whatever I try, I can’t seem to work with .mov or .webm videos with transparent background on Figma. Whenever I upload them, I get a black background. Am I doing something wrong? Or is there a workaround for this?
    Nik_Treiber
    Oct 22, 2024 3:15 PM UTC
    Also add me to the list of wanting and needing this
    R_Valgart
    Oct 25, 2024 2:09 PM UTC
    3 years and not fixed yet 😕
    Christian_Martin1
    Oct 31, 2024 12:17 PM UTC
    Yep, still not working. C’mon guys, it’s been years and I would argue transparent video is pretty fundamental. Do better.
    David_Jameson
    Nov 5, 2024 2:27 AM UTC
    maybe in 2025… …? lol
    Radim_Zeifart
    Dec 16, 2024 1:21 AM UTC
    Hello. I’ve come to the same conclusion as other users in this thread - the transparent webm file works the first time it’s uploaded for a brief moment. Then Figma decides “wait a minute this is transparent webm video, add black background at once and never be transparent again!”
    Would it be possible to fix this so the video is transparent forever? It’s obvious Figma can handle it because of my several successful tests right before the site forcefuly added black background.
    Brendon
    Jan 17, 2025 11:09 AM UTC
    It is 2025 and this issue makes my usecase impossible to solve in Figma and have to resort to other software. Why should I keep paying for a broken feature? But the AI hype is more important…
    Henry_Plant_VI
    Mar 19, 2025 3:39 PM UTC
    I’m beginning to think that figma is causing more setbacks than improvements on the transition over to AI design systems. It might be easier to feed illustrator files into gemini to code and then feed those into cursor for a prototype. Transparent video is pretty critical for prototypes and makes me question my over-reliance on this platform.
    Boz Bundalo
    Mar 30, 2025 3:21 PM UTC
    It’s kind of tale old as time. A company builds an incredible tool, then they get a taste of money, then they become complacent and continue working on things that will make them money instead of continuing to build upon the things that actually made them big to begin with and then another player comes out who cares about their customers and the circle begins again.
    transparent videos have been supported by browsers for years. Their whole platform is basically running in a browser. Why WebM and HEVC formats with alpha are not supported is beyond me. Let’s even say they don’t use HEVC because of licensing or something, webm supports it just fine.
    Paul_Vlachou
    Apr 24, 2025 7:57 PM UTC
    Extremely frustrating that Figma still doesn’t support transparent videos. Having said that, here’s a neat workaround for those with the compositing chops to do so in something like After Effects.
    1. Export a compatible video with no Alpha, such as h264.
    2. Create a black & white luma matte based on the alpha of your main footage. In AE for example, drag your main comp onto the new comp button; make a new white solid and use your main comp as the track matte layer (alpha); and then create a black solid for the background layer. Again, export this new comp with no Alpha, using h264.
    3. Drag both videos into Figma and align them on top of each other, with the Luma matte on the bottom. With both selected, right-click and “use as mask”.
    4. Go into the Mask group, select the luma matte video layer and set the Mask option on the right to “Luminance”.
    Hope this helps some folks in the meantime.
    Jay Eckert
    May 23, 2025 12:26 AM UTC
    You, sir… are a gentleman and a scholar for figuring out this bit of a hack. Thank you.
