Antoine
Oct 20, 2022 1:19 PM UTC
Nested property hidden with multiple selection
Been playing around with the “expose nested properties” feature currently in beta.
One of the great uses of variant properties is the ability to batch edit property values on multiple selected components. That use doesn’t carry over to exposed nested properties (yet I hope).
Demo file to help
When selecting one component instance exposing nested properties, said properties display fine. Add another instance of the same component to your selection (using Shift+Click), and the nested properties outright disappear from the right panel.
I haven’t seen this issue raised elsewhere! Do you experience it too?
    Jan 11, 2024 4:01 AM UTC
    have to make shitloads of variants instead of using nesting because of this 😢
    Paul_Lyons
    Jan 17, 2024 2:01 PM UTC
    Any news on an update to this @figma_support
    daken
    Feb 13, 2024 8:12 AM UTC
    need this man 😪 😗 😗 😪 😪 😪
    Feb 13, 2024 5:21 PM UTC
    Hey @Papes_Christoph,
    It has not been removed. Please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
    Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com so we can take a closer look.
    Feb 13, 2024 5:22 PM UTC
    Hey @daken,
    As mentioned above, this was already launched in November 2023.
    peter_fiek
    Feb 13, 2024 9:10 PM UTC
    I don’t think the solution was accurate to what the OP was asking because I’m having the same issue today. zach_ward2 explained it properly above.
    Yes, we are aware that nested properties can be exposed now, but when multiple component layers are selected, the nested properties disappear from the side panel.
    While these are helpful for some uses, this doesn’t cover the needs for the original issue/post.
    When selecting multiple components from a single component set, you aren’t able to adjust nested component properties. You have to select them individually to change them in the properties panel.
    frolovv
    Feb 14, 2024 9:31 AM UTC
    Hi! I checked the link and it seems to me that it doesn’t correspond to the question. When I select multiple instances, Figma doesn’t display the properties of the nested instances.
    Feb 20, 2024 6:48 PM UTC
    Hey @frolovv,
    The option to expose nested instances is available only if a main component:
    • already has an exposed nested instance, or
    • contains nested instances with component properties applied to it
    If you don’t see the Nested instances option, try applying a component property to a nested component first.
    More info here:
    Figma Learn - Help Center
    Feb 27, 2024 4:50 AM UTC
    Hi there,
    Around the 5-second mark in your video, it appears that you’re selecting two instances. Could you try selecting just one instance to see if the properties are shown?
    Additionally, please ensure that you’ve exposed the properties of the nested instances in the main component. If you see the properties of the nested instances like in the attached sample, you should be able to see them when you click on the instance individually.
    Please feel free to let us know if you hav further questions!
    Toku
