sebastien.giroux
March 19, 2021
Multiple independent strokes
  • March 19, 2021
  • 115 replies
  • 29543 views
You can currently set multiple stroke colours to an object, but they will share the same properties (thickness, position, etc.).
My idea is that you should be able to set all stroke properties on each stroke:
Make sense or am I missing something?
Alex_K
October 9, 2021
+1, I’d love this!
Sean.Mihaly
This 1000%.
It’s not uncommon for UI elements with multiple states to have multiple strokes. You can often use dropshadow effects with Spread to mimic this, but this doesn’t work on vectors. This is also a very common thing that is easily done using CSS. Bringing Figma closer to parity with what CSS can do will only benefit designers.
MMM
December 15, 2021
please add double stroke to object. now i can add different colours, but size change stroke to all colours. i can’t create stroke to object with free space between line and object. and can’t create two stroke lines with different colours
Frazer
December 21, 2021
+1 please. The separation in colour makes independent stroke width needed.
Keep it up crew, appreciate all the hard work!
Agne_Petrauskaite
January 7, 2022
Yes, please. Much needed 😊
Isaiah
January 13, 2022
Agreed, this definitely needs to be added.
Franco_Andrade
January 19, 2022
This is a must.
Nicolas_Simon
January 20, 2022
+1 I’d love this
Dylan_Reece
January 27, 2022
Just like Photoshop. You can say it.
donnavitan
+1 Need this please.
