Daniel_Amann
Lock section position
Sections are useful for organising the canvas. However, when I want to keep editing things within a section I keep selecting and moving the section accidentally.
Therefore, I would like to be able to lock the section position without locking the elements within the section.
Ida-Mina
November 1, 2022
I suggest anchoring the sections in place without locking the objects/frames inside them. It becomes tedious when I try to select frames and I accidentally move the whole Section.
November 4, 2022
Totally agreed! I just came here looking for this exact thing.
Sections are a great idea, but if I can’t drag to select frames within a section I can’t use them.
jonwilliamz
November 9, 2022
The new sections feature is good, but it could be better.
Before it came about, I was doing something similar with a locked frame to create an “Area” to group screens on top of. Sections achieve the same thing in an easier way, but…
The problem with sections is that if you lock them, you can’t access what’s inside of them. And if they aren’t locked, you risk accidentally selecting the section instead of the frame within it.
It seems if you’re at a certain zoom, then you can’t select it, but when I zoom out I keep accidentally moving things.
It would be great if sections remained locked until you clicked on the name tag in the top left corner. This could then activate editing the section.
Also, the name tag could be bigger 🙂
Cynthia_He
November 9, 2022
Totally +1. Can’t select a group of frames within a section is a pain.
Jared_e1
November 9, 2022
Interesting, is it kind of like pinning a section at a location so it can’t be moved but you can still edit what’s inside?
jonwilliamz
November 10, 2022
Yeah, exactly that. It should stay pinned and un-selectable until it’s unpinned. Perhaps until the user has clicked on the name tag in the top left corner.
Hi @Daniel_Amann ,
Thank you for your feedback! Others in the community have requested something similar, I merged your topic with the other ones so we can gather all the feedback under the same topic.
May 3, 2023
carynleiwe
Yeah, exactly. Very annoying not being able to control what element’s position I can or cannot lock while working on the elements within it. Please also allow the same for frames. Photoshop has such functionality to lock position only.
Joao_Vicente_Abreu
August 28, 2023
My suggestion is that the Section could be moved only when you select it via the title/name rectangle at the top.
