vdekkernl
November 16, 2023
Layers panel of the left sidebar should open at default
  • November 16, 2023
  • 19 replies
  • 476 views
Design documents open with the page panel closed by default. This is also true for the viewer role and the dev mode. I notice that stakeholders who view our design files have difficulty opening this.
This takes us a lot of time to explain each time. Now we have an explanation on our cover page of how it works to open this.
I think it actually makes sense if the page panel is open by default. Especially because Figma itself also gives advice on how to divide the design file with multiple pages. If a functionality is so default in use, it must also be open by default.
How are you experiencing this?
Best answer by Gayani_S
Hey everyone, wanted to give you a quick update on this issue.
Our team has investigated this and a fix has been issued and it should be released by tomorrow. Please let me know if you should still experience this issue after tomorrow.
Thank you,
Gayani
Joe_Garlick
August 21, 2024
TImes I have been working in a file and want the assets panel to show: 0
Times I have been frustrated that the assets panel is showing by default as it is a library but I want to access the layers panel: 1,923,328
OK OK, that is an exaggeration, but since I find the Assets panel confusing, poorly designed and not very useful, I never use it. I am always either copy/pasting components, or using things like ‘insert’. I NEVER want to see the Assets panel and I am constantly being annoyed I have to manually switch to the assets panel, many times a day.
I find it weird it defaults to that as well, cos when I am in a library I am working on the assets, not needing to pull them into the canvas. I also turn all my files that consume design system libraries into libraries themselves, cos I often make entire artboards into components so they can be duplicated elsewhere in the file and automatically update with changes to them, or place them into other files.
Power Member
August 22, 2024
I also never use it and never had this issue. Try clearing your app cache or reinstalling it. I didn’t even know it could open assets as default.
Joe_Garlick
September 5, 2024
Is the file you are working with a library? Cos it doesn’t do that unless you publish the file you are working on. I assume Figma decided this as they assumed a library needs that panel open by default? Which is a narrow minded view of how I use them.
Power Member
September 5, 2024
Not a library. It seems like it’s more about the way it remembers the previous state is buggy.
Joe_Garlick
September 12, 2024
I’ve cleared the cache, maybe that will fix it, thanks for the tip!
Often when I have restarted the app, or opened the file it would default to the assets panel for a library, I haven’t tested out if it always happens, just noticed it quite a lot. I’ve noticed it for years over multiple version upgrades/installs. Hopefully your tip fixes it! I didn’t know that feature existed.
Joe_Garlick
September 12, 2024
Hmm, still showing the Assets panel all the time, despite me not once ever selecting it. Similar issue: Layers panel of the left sidebar should open at default
Joe_Garlick
September 12, 2024
Heya, I have a similar issue, in files that are libraries the assets panel keeps being selected and shown by default despite me not ever once manually opening it. I never use it, and always want the layers panel to be shown. Is this expected behaviour?
Hey @Joe_Garlick ,
Thanks for reaching out to us! Can you share in details the steps you have done so we can try to replicate your issue?
The engineers confirm that the expected behavior is:
  • when opening a brand new file, opens the assets panel by default
  • on subsequent opens of any existing file, respect the users last Left panel state (either pages or assets depending on what they were last using)
(I’ve removed the previous message to avoid any confusion)
Gayani_S
Gayani_SAnswer
Thank you,
Gayani
Joe_Garlick
September 19, 2024
Thanks! The way I think about app UI in general and what happens on most other apps I use is that I expect the layers panel to be open by default on ALL Figma files I use once I have selected that panel. I also think the layers panel should be the default to open on all files, not the assets panel. It seems weird to me that UI has it ‘first’ as a tab, so that’s been decided to be a priority by the product designers, but that the second ‘assets’ tab is set to default to be open.
I expect this to be set at a global level, and that preference to apply to, at the very least, all files open inside one ‘window’ and ideally applied to all open files of the desktop app. I don’t expect this to be set at the file level. I am setting preferences for the app UI, not for a single file UI.
Not sure if this is what your engineers worked on but thank you very much for looking into it! Will report back if this is still an issue for me.
