Mr.Biscuit
Jan 23, 2021 3:44 AM UTC
LAUNCHED: True Aspect Ratio Lock
Can we get a true aspect ratio lock when the ‘Constrain Proportions’ is on?WX20210123-114719@2x A true aspect ratio lock means two things:
  1. When dragging on a node with ‘constrain proportions’, its width and height always stay in their original ratio no matter which direction you drag it.
  2. When resizing on the parent of a node with ‘constrain proportions’ that happens to be constrainedWX20210123-112532@2x, the node takes on the smallest of its supposed width and height, and calculates its ratio accordingly.
This would be so very helpful to polygon shapes that want to stay in that shape. Consider a spider chart. When you resize its parent, you don’t want the ‘spider net’ to squish squash; neither will you want a doughnut to turn into an oval.
*Resizing of the node’s parent layer is inevitable if you need responsive designs.
Pinned Reply By Celine_
Hey everyone, thanks for your patience! It’s fully rolled out now!
You can now lock the aspect ratio of almost any object in Figma – including frames, shapes, images, videos, vectors, and text – so that the proportions of that object are respected as you scale the object or its parent container.
 More info in the release notes here.
Seamus_Leonard2
Feb 19, 2025 2:02 PM UTC
This is a great enhancement and I’m looking forward to seeing how it place in cards and layout components.
One issue I’m having, since its ‘replaced’ the old control, it seems to have also ignored the previous setting. I have an icon library with a few hundred components that have all gone from locked ratio to not locked - so I have to turn on the new setting and re-publish.
Has anyone else encountered this?
Apolline
Feb 19, 2025 2:18 PM UTC
​@Seamus_Leonard2 I encountered the same thing, all or most of my icon components were ratio locked but they weren’t after the update.
Seamus_Leonard2
Feb 20, 2025 11:43 AM UTC
I’m sorry to hear this, but glad that I’m not just loosing my memory!
Another really weird thing is that its not tracked as a change in my library, meaning the file is not prompting me to ‘publish changes’ despite this modification.
Feb 20, 2025 7:18 PM UTC
Hey everyone! Thanks for sharing your feedback.
In order to help our team investigate, could you clarify the following:
  • When you manually re-enable Aspect Ratio Lock (ARL) does Figma prompt you to publish changes in your library, or does it not detect the change?
  • Before the update, were all your icon components set to “Constrain Proportions,” or just some?
  • What steps are you taking when trying to re-enable ARL and publish? (Feel also free to share a video recording if possible. We recommend uploading it to an external platforms such as Dropbox, Google Drive, or Loom, and sharing the link directly in your post.)
Thank you 🙏🏼
