Mr.Biscuit
Jan 23, 2021 3:44 AM UTC
LAUNCHED: True Aspect Ratio Lock
Can we get a true aspect ratio lock when the ‘Constrain Proportions’ is on?WX20210123-114719@2x A true aspect ratio lock means two things:
  1. When dragging on a node with ‘constrain proportions’, its width and height always stay in their original ratio no matter which direction you drag it.
  2. When resizing on the parent of a node with ‘constrain proportions’ that happens to be constrainedWX20210123-112532@2x, the node takes on the smallest of its supposed width and height, and calculates its ratio accordingly.
This would be so very helpful to polygon shapes that want to stay in that shape. Consider a spider chart. When you resize its parent, you don’t want the ‘spider net’ to squish squash; neither will you want a doughnut to turn into an oval.
*Resizing of the node’s parent layer is inevitable if you need responsive designs.
Pinned Reply By Celine_
Hey everyone, thanks for your patience! It’s fully rolled out now!
You can now lock the aspect ratio of almost any object in Figma – including frames, shapes, images, videos, vectors, and text – so that the proportions of that object are respected as you scale the object or its parent container.
 More info in the release notes here.
Craig P.
Jan 21, 2025 6:34 PM UTC
New figma user here frustrated that I can’t figure out how to get my icons to have a fixed aspect ratio.
Uhl
Feb 6, 2025 5:22 PM UTC
ahainen
Feb 6, 2025 5:43 PM UTC
Holy llamas, they finally did it!? 🙌
https://www.figma.com/release-notes/?title=aspect-ratio-locked
FINALLY. INSANE HOW LONG THIS TOOK
David_Simpson
Feb 7, 2025 12:47 PM UTC
Nice job Figma, thanks for getting round to this :)
an evolution i would like to see is aspect ratio variables we could apply to the lock
  • designers could pick from predefined ratio’s
  • developers could see that ratio in dev mode with either a raw aspect ratio value or a semantically referenced ratio
  • we could have code parity to aspect ratio tokens
Sayful_Islam_Shakib1
Feb 7, 2025 12:53 PM UTC
Didn't get this feature Figma please give me that! I really need it.
Celine_Pinned
Feb 7, 2025 2:18 PM UTC
AntoineP
Feb 10, 2025 6:42 AM UTC
The release is great (finally!) but it seems like the new ratio lock weirdly rounds up dimensions to the nearest pixel value (when you input a round value in width, height is round up causing a break in the aspect ratio, especially at very small, sub-pixel dimensions).
Anyone who worked with aspect ratio lock hacks knows that it’s annoying to have non-round heights but it should be the user’s choice to round or not. This currently makes the work of resizing vectors for icons very difficult.
Feb 10, 2025 1:58 PM UTC
Hey ​@AntoineP ,
Thanks for your detailed feedback! Does this occur with specific files or all files? And does it happen in the browser, desktop app, or both?
Can you try using the quick actions menu to turn off "Snap to pixel grid"?
Please let us know if this resolves your issue!
Apolline
Feb 11, 2025 8:14 AM UTC
The update is great, I wish the old icon was kept though, as it’s universal.
AntoineP
Feb 12, 2025 11:43 PM UTC
Hey ​@AntoineP ,
Thanks, disabling snap to pixel indeed solves the issue. I’m a little surprised because this wasn’t necessary to do the same kind of actions before the update. So now we have a slightly confusing behavior with snap to pixel enabled (which I would say is the default setting for most):
  • When using locked aspect ratio, dimensions are rounded to the nearest pixel value
  • In “free” aspect ratio constraints, they aren’t
Nothing indicates that this will happen, at least a tooltip would be welcome.
