Birgit_Stenzel
Apr 22, 2021 8:45 AM UTC
Launched: Manual resizing of sticky notes
1. Describe the bug/issue you’re running into?
I can’t resize sticky notes manually - this would be really nice though. I’m not sure if it’s a bug or a feature, but it feels like a missing Feature.
2. Are you able to consistently reproduce it? If so what are the steps?
Yes. Post a Sticky… try to change it.
3. Share a screenshot, recording, console log, link to the file, etc.
4. Is the issue only happening in desktop app or a specific browser , or both?
I can only test it in the browser Mircosoft edge (company policy…)
5. What OS/version and/or browser/version are you using?
Mircosoft Edge Version 90.0.818.42
Igor_Lacerdino
Apr 22, 2021 9:19 AM UTC
+1
I’m creating a click flow diagram and I wanted to add sticky notes to some steps with questions. The workaround for now is to re-size the entire flow diagram but it is more work to adjust text size later
samtcg
Apr 22, 2021 11:55 AM UTC
Hey there 👋 At this time, stickies cannot be resized. Stickies have a set width and minimum height. The height will change based on the amount of content you add to them. You can find more info in this Help Center article: Resize, scale, rotate, and flip objects
Kartik_Subramanian
Apr 28, 2021 2:29 PM UTC
Hi there,
I’ve recently started to use FigJam and I believe it’s a great tool to rapidly flowchart and communicate ideas to a team. I want to leave a sticky note in a couple of places and many a times they vary in the type of content within them. Can you please allow for a feature to re-size the sticky note?
Thanks
Igor_Alexandroff
Apr 29, 2021 10:58 AM UTC
Maybe you have it in plans at least?
Because I miss this feature so much and now have to use Miro instead…
Samson_Kirigua
Apr 30, 2021 7:07 AM UTC
This was the first thing I tried to do with sticky notes 😀
Yeah! … I need this feature.
Thanks!
Devansh_Raj
May 2, 2021 9:38 AM UTC
I want the sticky note to resize horizontally too for long titles.
And can we have multiple text style in one sticky note?
Because I want to use it for work and define the title and then the points in different text in the same note.
Adam7
May 3, 2021 9:14 PM UTC
This seems basic and throws off my workflow when transitioning from Miro (well, assessing if it’s possible, little things like this make it hard to convince unfortunately)
Nadia_Eldeib
May 6, 2021 4:01 PM UTC
+1 to this. Also, it seems like this functionality existed but went away? I noticed a weird behavior if I grouped a sticky note + dot sticker, then tried to resize. The dot sticker would overlap with text. Now I can no longer figure out how to resize at all.
Polca_Creations
May 18, 2021 8:05 AM UTC
Please make it possible to resize Sticky notes on FigJam.
Cait_O_Reilly
May 20, 2021 11:39 AM UTC
Would love the flexibility to resize Sticky Notes and have the text size also increase/decrease in size. Having fixed text styles doesn’t provide enough variety.
