RizePoint_Product
Jun 29, 2023 10:51 PM UTC
[LAUNCHED] All plans should offer more than 4 variable modes
It would be great if the professional plan offered more than 4 variable modes. Right now I want to set up a mode for each component size-- XS - XL, 5 sizes all together-- which puts me over the 4 limit for pro, but well under the 40 limit for enterprise, which is a quantity I will never need. And there’s no use case for enterprise at all for a team our size.
I think 10-12 modes for pro would be perfect to give small teams like mine room to grow before we reach the scale where an enterprise plan would be worth consideration.
Pinned Reply By jjcm
It’s finally here - mode count updates across Pro and Org.
Pro → 10
Org → 20
I want to thank everyone who posted in this thread - we used a lot of the responses here to inform the mode increase decision. Happy theme swapping y’all :)
Jason_Thompson
May 1, 2024 8:46 PM UTC
I’d even love to see 10-12 modes in the Organization plan. If it’s going to cost three times as much as Pro, how about three times the modes?
Maybe instead of 4-4-40, it’s something like 4-12-36?
Power Member
May 2, 2024 11:12 AM UTC
Here is a new plugin that allows you to have pretty much infinite modes: it helps you swap variables between different collections, even between libraries. Basically works like Swap Library for variables.
https://www.figma.com/community/plugin/1334258818515407420/swap-variables
Lucas
May 2, 2024 2:17 PM UTC
As predicted, cue the hacks plugins to get around this arbitrary limit.
Thanks for the resources @Gleb
Haleigh
May 2, 2024 6:03 PM UTC
Hello, our organization is also running into the issue. We have 1 product that needs to scale across 30 brands, each brand has a light, dark, and accent mode. So in total we need 90+ modes in one design system file.
Are there any current work arounds for this? if I create 3 separate variable library files with 30 modes in each- can those libraries still apply to one design system file?
Is there any future updates that will expand the amount of modes?
S_e_b_a_s_t_i_a_n
May 3, 2024 7:07 AM UTC
My suggestion:
Professional: 5
Organization: 10
Enterprise: 40
That would be fair.
Ben_Smeets
May 3, 2024 7:29 AM UTC
The whole concept of these limitations make no sense to me.
Diogo_Ramos
May 3, 2024 5:33 PM UTC
Jumping in here, we’re in the same situation as Haleigh, as even with an Enterprise plan the limitation of 40 modes is too restrictive for our use cases, with multiple clients and themes/modes.
JDPoZ
May 3, 2024 7:40 PM UTC
Really the “40” modes limit for variables should be for organization tier and variables should not be limited in any version since there is SO much out there you can’t even try if you don’t have at least one of the higher tier licenses.
Enterprise should be much larger and designed to flex to work with massive databases you’d expect massive enterprises to have needs for.
Hoby-Van-Hoose
May 4, 2024 12:52 AM UTC
I don’t agree that any limitations would be fair.
Hoby-Van-Hoose
May 4, 2024 1:05 AM UTC
That plugin looks interesting and useful a slightly different purpose but it doesn’t appear to be a great supplement for modes. It doesn’t dynamically cascade and I guess you’d have to put variable sets in a bunch of different files, however many you’d want to swap between.
