MayaShendelman
Jun 9, 2021 11:04 AM UTC
Keep Comments pinned to design elements (including nested)
When i move my design elements/frames/etc., I expect all the pinned comments to move with them – but they don’t. instead i’m left with a bunch of floating comments (that are not attached to anything), which requires me to manually re-read each comment and move it again to its correct place. this is frustrating and time consuming. but what’s worse is when another user forgets to move the comments after they move the design elements, so when i return to the Figma file it’s very difficult to decipher the floating comments because they are not pinned to anything so i have no idea what they’re referring to. please keep Comments pinned to design elements (so moving design elements automatically moves comments).
Craig_Garner
Oct 12, 2023 10:20 PM UTC
+1 for a more robust comment pinning solution. I can’t believe it’s been this long, with this many comments and still there is no way to pin a comment to an element within an auto-layout.
Oct 17, 2023 8:10 PM UTC
Hello Everyone,
I wanted to share a solution, which may not be perfect but at least works for me
Here are the steps:
  1. First, relocate the component or element where you intend to pin the comment outside of your frame. (Make sure it’s placed outside the frame.)
  2. Next, add your comment on the element.
  3. Finally, move the element back inside the frame.
After that my comment stays always in place.
I hope this is helpful for you.
Mark_van_Hagen
Oct 25, 2023 8:14 AM UTC
This “works” for me, but I hope a fix will come. The “solution” video by @Gleb indeed seemed to work for those easy cases. But when I add some comments to a design afterwards (with nested frames) and start moving things around the comments don’t stick to elements as expected.
Mark_van_Hagen
Oct 25, 2023 8:49 AM UTC
In addition to this idea of a temporary solution.
  1. When adding comments I just add a random shape (small) next to the design on the blank artboard. So not within a frame.
  2. Add my comment to that element.
  3. Drag it to the position I wanted the actual comment to be. (Optional set the shape to absolute position for more control.)
  4. And then I hide the element CTRL + Shift + H.
Now I can move everything around and the comment is always where I want it to be.
! A big downside… the comments placed this way don’t show up in prototypes, and it doesn’t make a difference if you hide the element yes/no…
deletedlc
Oct 28, 2023 4:29 PM UTC
absolutely. It’s great to get stakeholders involved in the process HOWEVER if the tools to support that are not in place the involvement could turn into anything from an embarrassment to decreased trust of the stakeholders in the design team…
deletedlc
Oct 28, 2023 4:30 PM UTC
imagine if Jira/Github/Jira & Github integration’s comment feature is broken or not working as expected…
Rob12
Nov 3, 2023 9:52 PM UTC
I would also like to bump this.
Please pin comments to components within an auto layout.
Anthony
Nov 6, 2023 9:46 AM UTC
I’ve just encountered this issue! Comments are attached to the frame and not the component within. Very annoying.
Dominik11
Nov 7, 2023 10:13 AM UTC
Very important for me, too. Please bring this feature back 🙂
Matheo_Lesage
Nov 9, 2023 4:42 PM UTC
I am not quite sure if it has been already mentioned but it would be awesome to be able to cut/paste comment within a frame. Right now when you cut a frame the comments stays on an empty space in the page and you have to move every one of them manually to “re-associate” them to the corresponding frame
