Erling
March 29, 2023
Improve the New Position Sticky Implementation
Am I the only one who’s left wanting by the new position sticky feature?
In my opinion, there are three main problems with the new sticky feature:
  1. It’s not compatible with auto layout
    • SolutionMake the sticky elements always appear on top of other elements (and later add a z-index feature so we can fine tune the behavior)
  2. The sticky element has to be an immediate child of the scrolling container
    • SolutionMake the sticky behavior relative to the closest scroll container instead, so the sticky element can be a grand child, great grand child etc.
  3. Only works for vertical scrolling and can only stick to the top of the container
    • SolutionAdd an offset property (top/right/bottom/left) - like the CSS implementation - super simple, but pretty flexible (only problem with the CSS implementation is the overflow: hidden limitation)
What I want to be able to make
None of which is possible with the new sticky feature unfortunately
HTML prototype
  • Note the sticky footer inside the container
  • Note that the elements stick relative to the window’s scroll position - it doesn’t care that the sticky element is far down the DOM tree
  • Check out the Codepen here
Figma prototype
  • This, only with auto layout
Sticky on larger screens (multiple columns etc + support for sticky in components)
  • I actually am working on a layout a bit like this (two columns with multiple sections in each). Being able to more accurately prototype it would be gold!
  • I would like to be able to create one component for each section. Within that component, I would then like to set the section heading to sticky
Edit: I initially just wanted to start a discussion and rant about how the new position sticky feature was implemented, but as the post was moved from “general discussions” → “share an idea” section, I felt the need to amend my post. I hid the rant below 😛
Just me ranting about how I'm disappointed by the way Figma implemented position sticky
Figma, why do you mock us so? (Position sticky discussion)
Yesterday Figma announced a lot of really nice quality of life improvements in their Little Big Things update. All good stuff, but the only thing that got me personally (very) exited was the position sticky feature.
Am I the only one who’s left utterly disappointed?
I thought Figma were committed to the auto layout feature, so why do they mock us so? Position sticky is in no way compatible with auto layout! (1)
The best I could do with position sticky:
  • Notice the oversized containers (colorized). They have to be that tall to make the element stick beneath the sticky tabs
  • The first element sticks nicely, but it will overlay any other sticky layer below it
They can probably fix this issue by just rendering sticky elements above the rest or something, but there is also another, bigger problem.
Problem 2
The biggest problem with the new sticky feature is a more fundamental implementation detail, which I suspect they won’t fix - thus, making me very pessimistic as to the usefulness of the feature (and it’s future). The problem:
You can only set position sticky if the immediate parent container is a scrolling container
This means that if you want to take advantage of position sticky, you have to have a totally flat layer structure - which again, is not compatible with auto layout! Or even components for that matter! (3)
The fact that the direct parent has to be a scrolling container, has always been the case for fixed elements, which has been an ok limitation (3) since fixed elements are detached from the layout flow.
Sticky elements on the other hand is a part of the layout flow, and is only detached from the flow just before it is scrolled out of the viewport. Them being a part of the layout also means that they has to be part of the auto layout, which is probably several layers deep due to how auto layout works.
Foot notes
(1) This is a bit of an over exaggeration. I know position sticky technically is compatible with auto layout, but due to auto layout’s strict z-index hierarchy everything will overlap the sticky element. “Just switch the canvas stacking”, you say? Then the next sticky element will be overlapped by the first element…
(2) When using auto layout you will end up with a deeper layer structure than you would without. This is because you have to the paddings and gaps on the auto layout containers, and in order to have different spacings, you need more and nested auto layout containers. This is perfectly reasonable and a boon to the structure and organization of files. It also makes the mental model of designing within Figma more like the mental model when writing the code.
(You can maybe get away with a flat auto layout structure on mobile mockups sometimes, but on desktop mockups it’s almost never the case).
(3) It’s been an ok limitation, at least after the position absolute feature was released and we could combine position fixed with auto layout.
Notes
I know that implementing position sticky is probably very tricky. But I think this is one of the cases where doing it right or not doing it at all would have served you better.
Figma has again and again spent the time to do it right, which makes me all the more disappointed this time around. It’s been so exiting to read the Figma blog on why seemingly easy to implement features are anything but.
I suspect there won’t be any such blog posts about position sticky 😦
Anyhow; I just wanted to put this rant out there. Please drop a comment if you agree/disagree. Would be nice to have a discussion about this.
Either way, have a good one! 😃
March 29, 2023
Interactions inside a group that is sticky do not get sticky. They scroll with the parent. While the whole group (in my case, a component for a navigation menu) gets sticky, the “interactive areas” scroll with the parent, making my navbar unusable.
Romijn_van_Soest
March 29, 2023
Nice feature! However when I make my frame that has a horizontal scrolling in it, stick to the top, somehow the horizontal scrolling doesn’t work anymore.
Viktors
I agree that it must also work with the auto layout, but it is one giant step forward. Finally, I can stick element after scroll! I love you, Figma!
Simon_Field1
With the much anticipated release of sticky elements in prototyping, one improvement stands out as being needed to really make this a game changing feature.
If you have a fixed header with sticky elements underneath it, that fixed header will overlap on top of any sticky elements, but it would be great if sticky elements would stick below any fixed items inside a frame rather than at the top of the frame.
In the below example, the grey bar represents something like a top bar within a native application, and the coloured bars could be section headers, content blocks, etc.
Figma – 29 Mar 23
The workaround is to artificially increase the height of the sticky component to include the ‘dead space’ where any fixed element will overlap with it, but this is clunky and adds a lot of extra overhead when creating prototypes, especially when using auto layout.
Ade_Chrisnadhi
March 29, 2023
would love to see this feature evolve
maybe adding “sticky to parent” or “choose element to stick to”
Thanks for the feedback @Viktors!
We’ll pass this feedback along to the team and merge your reply with another similar topic, so the community can continue to add their feedback and vote for improvements.
Erling
ErlingAuthor
March 29, 2023
I agree that this is a problem, that’s why I proposed adding an offset attribute (problem 3 → solution).
[…] it would be great if sticky elements would stick below any fixed items […]
I think we might need a manual solution to this. If they just made items stick beneath the fixed elements, what would happen if you had a fixed element in the middle of the screen? Or a fixed bottom app bar?
Do you think an offset value would solve your problem?
Erling
ErlingAuthor
March 29, 2023
It is a giant step forward indeed, and I’m really happy that they have taken the time to work on it!
I’m just concerned that they have implemented it with a too narrow use case, and that they are digging a hole - implementation wise - that will keep the use case too narrow (without major rewriting) 😦
Naiomi
March 29, 2023
I was so excited about this feature, but especially for stacked content and lists (which is where I imagine most people are using the sticky feature) I don’t know how you could not use auto-layout. I had to look through the forums to realise that the reason it was doing funny things for me was because I was using auto layout 😅
In other words, +1 from me!!
March 30, 2023
The new sticky/fixed features are really useful - however it would be great if you could limit these features to within a certain frame.
Because you can’t control the end point you just have your fixed content overlapping content below it…
