matuolowp
Apr 3, 2026 1:22 AM UTC
Improve error messaging for API/MCP access when Dev seat users lack project edit permission
Hi Figma team and community,
This is related to a similar issue reported here:
MCP rate limit not acknowledging subscription
I'd like to suggest an improvement to the error messaging around API and MCP access for Dev seat users.
Current situation:
When a Dev seat user tries to access a Figma project via the API or MCP without having edit permission granted at the project level, they receive this error:
> "You've reached the Figma MCP tool call limit for your View seat on the Professional plan. Upgrade your seat or plan for more tool calls."
This is misleading in two ways:
1. The user already has a Dev seat — not a View seat.
2. Upgrading the plan is not the fix. The actual issue is that edit permission hasn't been granted for that specific project.
There is also a conceptual confusion worth addressing: Dev seat users do not have edit access to projects by design, which makes it counterintuitive that they need to be granted edit permission by the project owner in order for API/MCP access to work. This distinction between "editing in Figma" and "API access permission" is not explained anywhere in the UI or documentation, making it very hard to discover.
The fix, once discovered, is straightforward: the project owner grants edit permission to the Dev seat user, and API/MCP access works as expected — no upgrade needed.
Suggested improvement:
Update the error message to reflect the actual cause. For example:
> "API access requires edit permission on this project. Please ask the project owner to grant you edit access."
This small change would save Dev seat users significant time and confusion.
Thanks for considering it!
adamsmasher
Apr 10, 2026 10:52 PM UTC
Hey ​@matuolowp! Thanks so much for your feature suggestion.
Our team is looking at your suggestion, and it would be super helpful for them to look at the file you are seeing this with. Do you mind sharing a link to the file here as well as sharing it with support-share@figma.com with view access? This won’t impact your billing and allows our team to reproduce and investigate further. Thanks so much!
peerless2012
Jul 15, 2026 5:05 AM UTC
Any update ?
Jul 15, 2026 5:44 PM UTC
Hi ​@peerless2012, thanks for chiming in here!
We’d love to be able to offer an update on this issue, but we actually never received a file URL link from the original topic creator. Because of that, our team has never been able to dive into this further.
If you have a file that you’re able to share with “Can view” access to support-share@figma.com, we can help get you connected with our support team to try to reproduce the issue and work towards a fix.
