AndyGandy
Apr 10, 2021 8:36 PM UTC
Fix Position when scrolling for background (or any other layer not on top)
Background scrolls with other elements. When I set “Fix position when scrolling” it jump upper and overlap other elements.
  1. Goal
Make background static when other elements can be scrolled on top of it.
  1. Solution
Add 3rd tab of scrolling type in the next order:
FIXED
SCROLLS
BACKGROUND or “BACK ELEMENTS” which is fixed but placed under the "SCROLLS’ layers.
Thanks!
rohangerrard_design
May 9, 2022 12:37 PM UTC
I want to be able to do this too - really challenging when fixed elements jump to the top!
Jeremy_Dennis
Jun 13, 2022 7:10 PM UTC
You can do this now with the “absolute positioning” option in the properties panel on the top left.
Cristian_Banu
Jul 21, 2022 12:26 PM UTC
Hi guys,
I still don’t get how to do this, I wanna have a static background as well. I don’t think I’ve seen a more non intuitive and non user friendly app than Figma, they seem to do everything out of spite, thank GOD not all clients and developers are obsessed with Figma.
Please, can anyone help?
Thank you!
Daniel_Racca
Jul 21, 2022 6:16 PM UTC
Yes, having the ability to decide which layers are fixed but still respecting the layering stack order from the side panel would be amazing 🙏
Jeremy_Dennis
Jul 29, 2022 5:57 PM UTC
Cristian_Banu
Jul 29, 2022 10:20 PM UTC
@Jeremy_Dennis
Thanks for the file bro :slight_smile 🙂
Howver, it still scrolls after the content is done scrolling. It doesn’t behave like XD, which is simply static, no “hacks” and workarounds needed.
Sairaj_Bhagat
Aug 26, 2022 12:14 PM UTC
Yea I faced the same issue and felt this solution would be best. I think there is some complication to it. But I would like to know what
Sairaj_Bhagat
Aug 26, 2022 12:34 PM UTC
I have a text layer blurred that I want to be there in the background as images come over it as the user scrolls. How can I do it?
I did not understand the work around that you explained 😅
Cristian_Banu
Oct 3, 2022 8:48 PM UTC
Makes zero sense to have the fixed elements above everything else. Also, makes no sense that the auto layout stacked elements’ z index depends on their vertical order.
Benjamin_Le_Roux
Oct 13, 2022 6:42 AM UTC
+1 Got this issue too… Would be great !
