eokic-hexis
May 5, 2021 12:22 AM UTC
Figma prototype UI obscuring fixed website header
    Screenshot and sample file below. I’m using an iMac sized frame with extended height. This issue is exacerbated by the fact that this is the now the default view when using multiple flow starting points and is the only way to actually change the flow starting point. So you have a constant trade-off of whether you want to see the Figma controls or your prototype’s. Annoying as hell.
EDIT: When sidebar is hidden, the fixed header is visible but inaccessible. As soon as the cursor hovers near it, the Figma UI appears over the (clickable) website header. Wow…
  1. Add as much context as possible (screenshots, Figma files, mockups, etc.)
    https://www.figma.com/file/WlYbWyHwtBGEFZihdMt2az/Bug-Obscured-fixed-header?node-id=0%3A1
James_Beardmore
Oct 13, 2023 2:53 PM UTC
Hey Figma, consider this:
I have been irritated by this feature for three years and today I finally came and said something. Every colleague or client I show a prototype to, or collaborate with, struggles to hide the UI that by default obscures the main navigation of many prototypes.
I bet for every person in this thread there’s another hundred who swear at your product every day for this obvious and unnecessary UI issue that undermines the core use of your product. Imagine how many will gladly leave Figma for a competitor as soon as it annoys them less than this does.
Your UI should not interfere with the content of a prototype by default! We’re UX designers! That’s a bad idea! By all means have an option for it to work this way but by default it should be above the design where it can’t get in the way.
Please listen to reason and fix it!
john-mainboard
Oct 19, 2023 7:53 AM UTC
When you view a prototype in full screen mode with FILL on, then the very top of the design - often filled with icons or small menu items or hamburger menu icons - cannot be accessed by clients, because the FIGMA header bar starts to appear, not only visually blocking the top part out, but also preventing actual clicking on those elements.
Jason_LaRose
Oct 20, 2023 6:36 PM UTC
Figma, can you perhaps put some sort of toggle at least on the header bar? If you toggle it on, the header bar shows at all times and pushes the design down. If you toggle it off, the header bar is hidden and the design slides up.
The header bar overlapping the design is kind of a big deal for your users, and a pretty bad UI/UX practice.
john-mainboard
Nov 2, 2023 7:03 AM UTC
Ok, I see the merged ticket now, but this doesn’t solve the problem. Clients still need to be able to change their view to see the design at 100% and switch back to full view (fit). This allows them to see the fonts at full size, even if their display doesn’t match the fit view (on a Macbook Air, the Macbook Pro screen is shrunk down significantly and shown in the tiny box in the middle, which is kind of weird in itself, so you can’t even make that fullscreen and share that, because if you copy the link with Full screen and UI off, you just get this tiny box in the middle with a huge black box around the design - this is really a lot of wasted space. there isn’t a way to share the prototype so that it fills the width and pretends that it’s a browser.
So even if I want to share these hidden UI, the client is then unable to switch to 100% and thinks this little box in the middle is their “website”.
This preview mode is really in need of some serious love.
Sameer_Chavan1
Mar 8, 2024 12:37 PM UTC
OMG… this issue is not yet solved after millions of people have shown frustration. Why is this being ignored for so long? The prototype should just start below that stupid overlay Figma UI. Or move that to the left panel in the menu.
Tara_Price2
Apr 25, 2024 10:55 PM UTC
This is still a huge pain point. Either move the design down, or allow a HIDE FiGMA UI by default.
Ioan_Butiu
May 20, 2024 7:36 PM UTC
This issue has been bothering me since I started using Figma. It’s incredible that such an obvious UI flaw hasn’t been addressed despite years of complaints.
Jun 15, 2024 9:58 PM UTC
Huge pain point. Bump
Harry_Higgins
Sep 26, 2024 2:46 PM UTC
Bump, this is still an issue. I’m constantly annoyed by this thing covering the UI by default.
Nellya
Power Member
Sep 26, 2024 3:01 PM UTC
Just add &hide-ui=1 to the end of the prototype link and client won’t see UI bar
