Marisol_Lopez
Apr 20, 2021 3:49 AM UTC
Export to CMYK
I want to be able to export designs in PDF for print (CMYK/Hi-resolution)
For now, I was using the plugin TinyImage Compressor but it’s no longer free and I don’t understand why Figma can have this option on it’s own. I’d have to pay $456 a year.
If Figma has paper sizes, why don’t they have this option… you can’t print quality good quality colors in RGB. I’m going to have to go back to Adobe for print files.
Is this happening to anyone else?
Eduardo_Santini
Nov 14, 2021 1:59 AM UTC
Totally agree, I work with Printed Cards for board games and FIGMA is perfect for it.
Uranbold_Nergui
Dec 21, 2021 1:48 AM UTC
I Love figma. Wishing to add CMYK for this Christmas 🙂
Nina_Alter
Dec 21, 2021 9:38 PM UTC
CMYK conversions from RGB can be quite “muddy.” I’d love this feature, IF Figma bundled conversion ramps in with a feature, offering “preview” choices before the conversion is executed—but I fear Adobe may have that stuff patented.
Constantine_Zuev
Dec 21, 2021 11:10 PM UTC
I would recommended to leave everything in RGB and convert to CMYK while printing, using printing drivers or whatever app is responsible. See long explanation below.
For a start let me clarify that Figma does not technically support color management. It is always sRGB for web, sRGB or Unmanaged on macOS. Latter is just whatever system decides, but likely your default display profile is used.
sRGB is considerably more limited in gamut compared to CMYK. You are trying to convert from something with limited number of colors to something that potentially displays significantly more of them but not all (sic). And so there are multiple legitimate options doing so, but many will be not best. Likely the worst unless… Unless you know the exact profile of printer you are going to print with.
That’s what color management is typically is. When you work in publishing you work with display that is specifically calibrated for its room. Using this profile and original file color profile system shows you best approximation of what you are going to get in print from your printer. Well, that’s ideal case.
Without proper color management it is the best to leave conversion from RGB to CMYK to printer itself. If you sending it to professional printing house, let them do it. For example professional photo printers actually have more than four colors. Beside Cyan, Yellow, Magenta, blacK they can have few grays, light yellow and light cyan at their disposal. Whatever conversion to CMYK you use it would end up duller then what printer itself will calculate.
creative_corner
Mar 10, 2022 10:42 AM UTC
Bro also need Inches Option
Henry6
Mar 11, 2022 12:45 AM UTC
This would be nice
Kevin_Denkers
Mar 30, 2022 9:49 PM UTC
Figma is an amazing design tool. Would be great to add the ability to use it for print, as well as screen design.
Ellen2
Jun 8, 2022 5:45 PM UTC
I know color spaces are probably so complicated but it’d be SO wonderful to be able to use Figma for print pieces, especially when making templates for clients!
designteam1
Aug 17, 2022 8:54 AM UTC
Bumping this for the year 2022
Ali_Jaya_Meilio_Lie
Aug 18, 2022 1:35 AM UTC
And mm would be good
