Antoine
May 19, 2022 12:11 PM UTC
"Empty" Auto Layout Frame keeps the size of last hidden child
Hi, I’m not sure if this is new since the May update, but I wonder why “empty” (all elements hidden) Auto Layout Frames keep the size of the last hidden child (and I do not mean last in the list, but the last element to have been toggled out of view by the user), making them not-0px high even with nothing in them.
See here a file with a Frame with three hidden rectangle: the Frame keeps the size of the last child rectangle to have been hidden. When adding a 0-px Frame to the AL frame, and toggling this 0-px Frame off last, the container goes 0-px.
In my opinion, empty AL Frames should have a height of 0. What do you think?
Pinned Reply By djv
Hey All, thanks again for your continued feedback, and I finally have an update!
As mentioned previously, this is behavior is currently a known feature limitation in Figma. We do not allow Auto layout frames to collapse to 0 when the child layers are hidden, so it is expected that the frame will remain sized as if they were shown.
The team has confirmed that they now have the bandwidth to get this working as expected. In the meantime, they have a temporary solution: Add a visible zero-sized frame. Since the container is then not empty, it will hug to the visible child, which is zero-sized.
While I know this may not be the solution you want, please know that we’re getting closer. I’ll be sure to update you all again once we have a more firm timeline on the fix.
Olha4
Dec 6, 2024 11:13 PM UTC
+1 ran into the same issue
Klindt_Fabian
Dec 17, 2024 8:00 AM UTC
In my opinion this feature limitation is a direct contradiction to what Auto Layout is supposed to do? Why would you intentionally add a feature limitation that makes the handover to developers so unneccessarily complicated?
In the Figma Learn article on Auto Layout it says: “Use auto layout to create responsive designs that grow to fill, shrink to fit, and reflow contents” and “Build lists that adapt as items are added, removed, or hidden” but it does not do that due to your feature limitation.
This issue is costing me and my team precious time not only during design, but also when collaborating with developers.
Klindt_Fabian
To everyone else following this topic: our workaround is creating sub-components. Let’s say you are building a card with an optional header, and this header is an Auto Layout containing a couple of different things (like an avatar and a time/date slot, for example, that are shown next to each other). Building the header as a separate sub component allows you to toggle it on/off in the card component. Exposing the sub component in the card component then gives you all the options you need (in this example, hiding either the avatar or the time/date slot independently from each other).
This is not ideal as you, theoretically, can turn on the header boolean and then turn off the two header booleans, which will replicate the bug that is being discussed here - but it does allow you to turn off the entire header.
Jiyeon_Yoo
Jan 15, 2025 4:10 AM UTC
+1 please fix
Lea.P
Jan 21, 2025 6:21 PM UTC
*Push +1
The workaround with subcomponents is not practicable.
This is absolutely not a feature. This is a bug.
And a biiiiiig problem for our design system.
It is not logical at all that auto layout frames keep their dimensions but all child layers are hidden.
Please fix this! thx
Tim_Print1
Feb 5, 2025 1:40 PM UTC
Really need a fix for this bug, it is completely illogical and breaks even fairly simple components with boolean contents.
Mads_Emmertsen2
Feb 6, 2025 9:37 AM UTC
+1 Hoping this gets fixed in the near future
Feb 20, 2025 3:33 AM UTC
+1 really need this to be fixed for design systems that our team implement
Andrei Gadoiu
Mar 3, 2025 2:22 PM UTC
+1. Though I understand the fear others have when dealing with a 0px height layer, this clearly breaks the way auto-layout works.
Alexander Girod
Mar 22, 2025 7:09 PM UTC
I guess AI is more important now than fixing this issue and provide real quality of life for professional users.
