Antoine
May 19, 2022 12:11 PM UTC
"Empty" Auto Layout Frame keeps the size of last hidden child
Hi, I’m not sure if this is new since the May update, but I wonder why “empty” (all elements hidden) Auto Layout Frames keep the size of the last hidden child (and I do not mean last in the list, but the last element to have been toggled out of view by the user), making them not-0px high even with nothing in them.
See here a file with a Frame with three hidden rectangle: the Frame keeps the size of the last child rectangle to have been hidden. When adding a 0-px Frame to the AL frame, and toggling this 0-px Frame off last, the container goes 0-px.
In my opinion, empty AL Frames should have a height of 0. What do you think?
Pinned Reply By djv
Hey All, thanks again for your continued feedback, and I finally have an update!
As mentioned previously, this is behavior is currently a known feature limitation in Figma. We do not allow Auto layout frames to collapse to 0 when the child layers are hidden, so it is expected that the frame will remain sized as if they were shown.
The team has confirmed that they now have the bandwidth to get this working as expected. In the meantime, they have a temporary solution: Add a visible zero-sized frame. Since the container is then not empty, it will hug to the visible child, which is zero-sized.
While I know this may not be the solution you want, please know that we’re getting closer. I’ll be sure to update you all again once we have a more firm timeline on the fix.
Fraser Hood
Mar 24, 2025 8:25 AM UTC
+1 this is starting and will continue to cause issues for designers and developers across our product teams
Kateryna13
Mar 27, 2025 4:52 PM UTC
+1 can’t properly use boolean show/hide in complex components
Nick89
Apr 16, 2025 6:27 AM UTC
+1
2 years later this has still not been fixed? This is starting to become like the "multiple independent strokes" topic. Still nothing while it's very much needed to prevent us from hacking our way through the application...
Onno_Willems
Apr 16, 2025 7:22 AM UTC
Ha, got here by googling why it behaves like it does and wondering if I was doing something wrong.
In my case: I have 2 items (set to fill width) that have booleans for their visibility in vertical auto layout. The hack with including a 0 height rectangle at the bottom in the auto-layout works, so I'm good. It's just that you loose a lot of time/productivity investigating such bugs, hunting for solutions, etc.
Joseph_Niet
May 6, 2025 7:32 PM UTC
+1 - making a card with booleans to toggle the visibility of items within an auto-layout. When they’re all turned off the height resets as if they were all visibile, instead of collapsing...seems totally counter-intuitive and broken to me?
Rob_Thwaites1
May 19, 2025 5:19 AM UTC
Hi folks, You can solve this with a little hack – I think its been mentioned here in this post, but I didn’t see a screengrab, so here it is:
  1. In Figma, you can set an element to have 0 height (I don’t think this was always the case, but you can do it now).
  2. However, an autolayout container has problems collapsing to 0 height, when it is emptied of elements - it does better when it has a containing element to set its height from, even if that element is 0 pixels high.
  3. Hence the fix is to put in 0-height stroke that will always be at the bottom of your stack. The Container will now reliably collapse to 0px height when all items are hidden inside it.
0 height quick hack
Mads_Emmertsen2
May 20, 2025 1:42 PM UTC
0 height quick hack
I tried this hack but the issue is that the stroke counts as an item so a gap will be created between it and the other elements which will then ruin the size of the frame 😅 so it only works if the frame has 0 gap.
real_witt
May 27, 2025 9:04 PM UTC
Like to have it the way it is. Hunting zero size frame somewhere buried in layers would be a nightmare
This is a nonissue though, you can still toggle the visibility on in
a) the main component by simply selecting the component (purple dotted bounding box) and toggling the visibility of whatever you hid via the properties panel
b) a component instance by doing the same thing (select component and toggle visibility in the properties panel
Collapsing empty containers in a component instance if all the container children are hidden makes total sense.
Vincent_Schlothauer
Jun 2, 2025 1:05 PM UTC
Chiming in to say this is a real bummer for design systems.
Say I can display 1, 2 or zero buttons in a banner. When I toggle off both buttons I expect the autolayout containing them to collapse, since it is, for all intents and purposes, empty. With the current behaviour I have to add another toggle for the button container, which makes the properties panel confusing to designers.
We used to use subcomponents to prevent some of these issues, but since running into major performance issues with our prototypes last year Figma recommended we use fewer nested components. So this is a lose-lose situation unfortunately.
Julia57
Jul 3, 2025 2:45 PM UTC
It is now 3 years later and still not fixed. It’s insane. there is no good workaround because even if I add a 0px frame, it will still cause extra space to be taken up due to the parent’s ‘gap’ setting.
