Roozbeh
May 11, 2022 3:10 PM UTC
Dark Mode asset library accessibility bug
After changing the theme to dark I have issue with component preview in Assets panel. The component background turned dark and dark components are not visible. Do you have the same issue?
Screen Shot 2022-05-11 at 16.08.58
Paul_Anastasiu
Nov 12, 2024 1:59 PM UTC
hey all, I found a work-around for this. basically Figma will default to whatever background you’ve used for the icons WRAPPER frame. so if your icons are part of the component set, you can add a background to that, and it will render your icons visible again. HOWEVER, if that frame is inside of a section, then Figma defaults to the sections color, so you gotta adjust that background color.
old topic, but finally solved!
