Roozbeh
May 11, 2022 3:10 PM UTC
Dark Mode asset library accessibility bug
After changing the theme to dark I have issue with component preview in Assets panel. The component background turned dark and dark components are not visible. Do you have the same issue?
Screen Shot 2022-05-11 at 16.08.58
Skvortsov_Mihail
May 11, 2022 5:14 PM UTC
The same issue with my icons libary…
Need white bg for preview
Roozbeh
RoozbehAuthor
May 12, 2022 10:48 AM UTC
I am reposting this because I didn’t get much replies and this rather an important issue. After enabling dark mode, the assets with darer color are barely visible in assets panel due to their dark background. Is there any workaround or we should wait for a fix?
Screen Shot 2022-05-11 at 16.09.04
Shelby_Zasacky
May 12, 2022 8:13 PM UTC
LOVE the new dark mode! Truly, excellent job and excellent talk at config Figma team.
The one thing that has been a bit of an issue is assets and components that default in light mode being super low contrast and very hard to see or use on the side bar. Even a mid-gray value for the cards would be a bit better as a quick fix! I’ve attached an example of the Microsoft fluent icons
Pavel_Kiselev
Power Member
May 12, 2022 10:04 PM UTC
Well, if you design dark with light mode on, it is not any better 😉
Adam_Ogrodnik
May 13, 2022 8:34 AM UTC
Try to wrap them in a frame with light bg and re-publish.
Brute force workaround: you can also try do just add bg to all these icons.
ahmad_tabby
May 22, 2022 7:29 PM UTC
Same issue with icons, can’t see anything. Always need to switch to light mode to view these assets.
ahmad_tabby
May 23, 2022 7:24 AM UTC
Facing the same issue. Forced to switch to light view to view these assets. Dark mode isn’t useful at all until this gets resolved.
Atiqur_Rahaman
Jun 3, 2022 10:29 AM UTC
Same issue. Need an update for that
Aug 10, 2022 10:05 PM UTC
Phil_Larsen
Nov 4, 2022 12:32 AM UTC
This issue is still persisting for me, however it is more the labels that give me trouble. In light mode the text is legible, but in dark mode something isn’t adjusting properly resulting in poor readability.
