Meghan_Rose1
Jun 22, 2023 9:19 PM UTC
Copy/Move variable groups into other collections
I have been playing around with creating variables but realized I would rather have groups in separate collections, but cannot move them.
I would like to be able to duplicate an entire collection so I don’t have to manually re-create values and can remove what I don’t need from that collection OR simply be able to move groups into other collections.
[The title of this post was edited from “LAUNCHED: Copy/Move variable groups into other collections” to “Copy/Move variable groups into other collections” by a moderator on 17-Jan-2026.]
Matan_Rosen
Aug 3, 2023 7:10 AM UTC
Yes, please!
I need to separate my core token from my semantic ones
Saurabh
Aug 8, 2023 5:01 PM UTC
Greetings Everyone,
I trust you’re all experiencing blessings.
Much like everyone here, I encountered a challenge. However, given that Figma currently lacks support for this particular feature, I devised a clever workaround. Please note that this approach is applicable in specific scenarios where the following steps have been set up:
Additional steps may be required, approximately 2-3 in total:
  1. Ensure that your styles are associated with variables. Additionally, confirm that you have effectively organized most of the primitive and semantic colors within a nested structure.
  2. Run the “Import/Export By Honza Toman” plugin.
  • Export your existing variable collection to a JSON file.
  • Modify the collection name within the JSON file.
  • Import the modified JSON file using the same plugin, and voilà, your existing collection is now duplicated! ❤️
Enjoy the enhanced functionality!
Milos_Mirkovic
Aug 9, 2023 8:07 AM UTC
Hi Saurabh,
I think that duplicating collection is not an issue. You can do the same with running plugins such as “Styles to Variables” or similar. You just need to run it, rename the collection and then run it again.
The issue that I am experiencing is that I want to separate Primitives and Semantic in different collections in the same Figma file. All my color styles live in the single Foundations file. With a help of plugins such as “Styles to Variables” I can easily create variables in a batch and automatically connect them with Color Styles. But, once you do any duplication (either with your approach or the one I described) you lose half of the connections, Primitives or Semantic, depending on which are going to be overwritten.
If anyone found a solution to this, please share 🙂
Kirk_Wheeler
Aug 9, 2023 1:58 PM UTC
Please consider adding the ability to move a single variable or a group of variables from one collection to another. I’m working through how I want to try to organize these and not having the ability to move them makes it a lot harder as I’m figuring this out as I’m doing it.
Aug 9, 2023 4:59 PM UTC
Thanks for the feedback, @Kirk_Wheeler!
With variables still in beta, we’ll pass this onto our team for consideration as variables continue to evolve and grow.
Marie_Rang
Aug 10, 2023 2:37 PM UTC
Oh my god YES! This is a major thing that is missing…
Greg_Huntoon1
Aug 11, 2023 4:59 PM UTC
This is a great workaround! Thanks for the suggestion.
Arvid
Aug 22, 2023 12:12 PM UTC
Still out of votes, sadly, but +1 from me xD
I guess these are duplicates? @dvaliao
Arvid
Aug 22, 2023 12:14 PM UTC
+1 from me
Jermold_Compton
Aug 23, 2023 10:26 PM UTC
I’m surprised this wasn’t a feature at launch. This needs to be a feature!
I’ve already encountered quite a few instances across my team where variables needed to be moved and it’s not possible without exporting and re-importing. The issue is that it breaks the nested variables when using this workaround.
Has anyone come across a workaround/plugin that doesn’t break the nested variables or relinks the nested variables when collections are imported?
