aelveora
Dec 11, 2023 12:11 AM UTC
Control nested components properties
Please make it possible to control which properties of nested components (atoms) can be used in higher components (molecules).
What if I use same nested component in different objects and I don’t need some properties in both of them?
What if I don’t need some booleans which is part of variants of that atom in molecule?
Please fix it, thank you.
Gayani_S
Dec 11, 2023 2:49 PM UTC
2 posts were merged into an existing topic: Reorder nested porperties
Gayani_S
Dec 11, 2023 2:58 PM UTC
Hey Dmitry, thank you for raising this feature request. Could you give me more information on this? I am not sure if I am understanding first request correctly.
Also, I’ve merged the third one with a similar, so you can vote on the main page.
aelveora
aelveoraAuthor
Dec 24, 2023 1:53 AM UTC
For example.
I have Icon Button with 5 different types and 3 sizes: Small, Medium and Large. And I use this Icon Button as a nested item inside some Bar, and I want to have an option to change icons, however size and type of Button must be forbidden to change and always be Ghost and Large.
Just add checkboxes like this
Gayani_S
Dec 29, 2023 11:41 AM UTC
Got it! Thank you for explaining.
Mikhail_Guguev1
Jan 18, 2024 6:09 PM UTC
When can we expect such functionality? By implementation looks like not a difficult task.
Alex_Ter
Jun 21, 2024 4:24 PM UTC
When will this feature be added? You can use the approach that is used in published and non-published components, if there is a dot before the name, the element will not be inherited above, if it is difficult to implement with checkboxes
Jared_Gibbons
Aug 16, 2024 9:07 PM UTC
This would be a huge improvement to maintaining consistency and mitigating the risk of designers accidentally changing defined patterns and styles in published components.
Kara_Miekina3
Sep 9, 2024 7:39 PM UTC
PLLLEEEASSSEEEE this. please please.
Oriami
Sep 20, 2024 2:32 PM UTC
Here is a real life example where this feature is missing. In the new interface, this has become critical. I can no longer see the most important thing because the nests cover everything. Please fix this.
Raymond_Uphoff
Nov 15, 2024 4:23 PM UTC
Thought it’s A really old topic.
I think it’s the one thing Sketch is better then Figma. For years you can configure which properties are being inherited and which not in Sketch. In Figma it’s all or nothing approach. When designers apply abstraction, nested components, to keep things simple, as in not repetitive tasks, having finer control of properties is a must. Otherwise you can control the same settings on different levels and it clutters overwrite panel with, what we designers don’t like, noise!
