Ethan_Wang
Oct 10, 2022 6:43 PM UTC
Change the order of exposed nested instances
It doesn’t look like there’s an obvious way to change the order of exposed nested instances. Right now the order seems to be based on reverse layer order. It’d be great if the order can be manually adjusted.
Screen Shot 2022-10-10 at 11.44.08 AM
Seamoose
Feb 15, 2024 11:08 PM UTC
This would be really nice, please!
Feb 16, 2024 2:06 AM UTC
Hi all, Thanks for sharing your thoughts about nested instance properties! I will make sure to bring this up with our internal team for future consideration.
Marcus_Vedde
Feb 27, 2024 3:44 PM UTC
Great news!
ZdenekCulik
Apr 18, 2024 2:43 PM UTC
+10 please
r_sh
May 16, 2024 8:41 PM UTC
Yes, it would be SUPER helpful for our team to be able to reorder the nested instance properties (without changing the actual order layer of the instances in the component-- with autolayout, the actual layer order matters a lot!)
Julius_Klaus
May 16, 2024 8:47 PM UTC
+100000. Plus it would be nice to be able to select which properties of a nested instance are being leaked. I’m building complex design systems for clients, so they are able to quickly export customized versions of a template. But sometimes i need to restrict the client to being able to change all of the properties.
Liz_Brenner
May 28, 2024 11:04 AM UTC
10000000+ need this feature!
Iris_van_der_Looij
May 30, 2024 11:30 AM UTC
+100%, please make this available!
Patrick_Flanagan
Jun 5, 2024 1:14 PM UTC
+100, yes it would be so great to even pull apart the items, so that a nested item’s property could be placed anywhere, or hidden if needed.
Dan_Brown1
Jun 11, 2024 3:31 PM UTC
Replying to keep hope alive!
