RG_man
Feb 11, 2021 9:02 AM UTC
Better plugin window management (fixed sidebar, multiple windows, stacking etc.)
I can open 1 plugin at time, the plugins are located only in plugin section. I don’t have any possibility to add plugin to UI (exp. sidebar). Also plugin windows can be opened only in Figma webview window.
2. Add as much context as possible (screenshots, Figma files, mockups, etc.)
example of sidebar for plugins
3. Ask questions to bring the community into the conversation
Does anyone else have same problems?
Alexiss
Apr 4, 2023 5:09 AM UTC
It’s not a version issue, they just removed the plugin.
D111
Apr 5, 2023 1:03 PM UTC
it returns me 404 😭
Apr 5, 2023 6:47 PM UTC
Sorry for the trouble!
This plugin was flagged by several other creators in the community, since it would scrape the code of other plugins. We were forced to remove it from the community, since it went against our Community Guidelines.
We hope to implement better plugin management without the use of a plugin in the future.
Clarck
Apr 28, 2023 5:17 AM UTC
I’m reopening this discussion, this fits the Big little updates of Figma.
This improves the experience of using plugins by large and I suggest you can like to minimize them at the bottom of the screen where it is unintrusive when designing and does not get in the way.
Dmitri_Albert
Sep 26, 2023 9:54 AM UTC
Several plugins running at once is definitely a must. E.g., I need to have Tokens Studio for Figma plugin open and at the same time Zebra plugin to check color-proofing. Switching plugins constantly is very annoying and insufficient.
Iandesu
Nov 8, 2023 10:27 PM UTC
I’ve discovered a temporary workaround to display plugins on a second monitor! Simply open another Figma window with the same project (one in the browser and one in the Figma app), then open the plugin in the browser window. Voilà!
SohrabNiroo
Nov 11, 2023 8:00 AM UTC
We really need to have sidebars to be dragged outside the Figma app, like Photoshop, it’s taking up so much space. Pleaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaas!!!
Isaque_Pereira
Feb 28, 2024 3:46 PM UTC
For gods sake yes, I need this more than copying and pasting prototype noodles 😅
Apr 29, 2024 2:04 PM UTC
It’s 2024, and Figma doesn’t give a damn!
Martyn_Bowis
Jun 11, 2024 3:08 AM UTC
External windows for plugins would be best for my plugins and those I use please.
Restricting plugins to a sidebar would be worse than current situation of being able to place the plugin window anywhere over the top of the Figma window.
Being able to run multiple plugins would be helpful.
Thanks!
