Peter_Uithoven
July 22, 2024
Allow subscript and superscript as text style overrides?
  • July 22, 2024
  • 12 replies
  • 3020 views
Since a recent release we can already do some text style overrides. While maintaining the connection to a text style we can bold, italic and underline by using keyboard shortcuts.
Example in UI where I made a part bold:
Is there any change we can get the same feature for subscript and superscript? This would enable us to maintain the text style, while entering formulas like:
Formulas
Currently I have to disconnect the text style and then change the position. Which also isn’t the easiest feature to find.
This probably also requires putting making something sub- or superscript under some kind of keyboard shortcut, it currently isn’t:
Note that there is no problem using m³ for example, because I can just enter these as characters using my compose key (on Linux).
Thank you very much for the detailed feedback. I’ll share this with our internal team!
Kat_Sampson_Sutton
July 24, 2024
Looking for a similar solution. I want to include registration and trademark symbols in my text without breaking my text styles!
Alexander_Ovcharenko
August 27, 2024
Hi, yes, it is important, because as we are working a lot with emissions regulations, making subscripts/superscripts for all these CO2, NO2, square meters, etc. is always painful — even without styles you always have to click another tab, then scroll down to find the selectors, but with design-system styles support it becomes impossible.
Also, it would be nice to have copy-paste to save the subscripts and superscripts status of symbols – right now it is lost and you have to apply it again
I would suggest not to consider subscripts and superscripts as the elements of style — while technically they are defined by HTML tags, semantically (for units and chemicals) they are just additional symbols, like “°” (degrees), it is perceived like a single word. Also, it is odd to imagine the subscript text style used for the whole paragraph or several words.
Peter_Uithoven
August 29, 2024
You can actually already just enter subscript / superscript things like 2, just like I can here: m². But this is limited to a specific amount of characters:
en.wikipedia.org
So I can’t use this functionality for the formula’s I commonly need to enter.
On Linux I can use the compose key to input these. Compose key + ^ + 2 gives me ². Compose key + _ + 2 gives me: ₂.
September 17, 2024
Peter, yes, but it doesn’t solve the principal problem of using styles consistently and using other symbols (as you mentioned, maths formulas, etc.), so workarounds with standard Unicode symbols don’t help that much.
Jake_Schroeder1
Just wanted to lend my support for this request. The same way styling like bold and italics are able to be added without breaking a style, it would be incredibly helpful for users in the medical field where a lot of references are being cited throughout blocks of paragraphs. Right now we are having to break the styles several times in one block of text.
Martin84
October 23, 2024
All the co2 projects out there are designed in broken text styles 😶‍🌫️
This is a tiny fix but a huge improvement for something that can be very repetitive for some, including me.
Winter_Ryan_RGA
Adding to this. I deal with large amounts of disclaimers in text (eg. ‘and Notice[DH1]’) and have to break styles constantly to make things superscript. Being able to do this without breaking the style would be a huge benefit 🙏
Charline Leger
Adding to this, I have to use superscript a lot and it’s pretty laborious to have to unlink the style every time. Is an update planned anytime soon?
Antoine
May 28, 2025
Superscript and subscript overrides now seem to be available. I’m not sure when it was rolled out.
