Aaqil_Jamal
Jan 16, 2024 3:08 PM UTC
Allow link to be clickable when using embed links from Figma to Behance
Allowing to embed links in Behance is helpful but it would be great if it’s taken to the next level.
Currently, once you embed a link on Behance, you can scroll down and view the design, even clicking prototype works like a charm. One issue I’ve faced is in embed view the prototype doesn’t allow clicks that take the person outside of Figma. I created a case study in which I added links to my research captured in Google Docs thinking it would take the user there if clicked but anything that takes the user out of the Figma link doesn’t work. If we can fix this it would be great as we won’t have to add images on Behance and my case study could become more lively and easily managable.
Thanks
Aug 9, 2024 1:39 PM UTC
U have a solution???
Aug 9, 2024 1:40 PM UTC
Any solution? I cant open links in Behance but in Figma yes
Gayani_S
Aug 12, 2024 2:26 PM UTC
Hey @Emiliano_Ostertag, thank you for reaching out! Can you please check my previous reply. I would need this information so the team can investigate further.
Adrian_Cerbaro
Aug 27, 2024 8:17 PM UTC
Hello, I have a similar issue.
I’m trying to embed a FigJam in a web page, but the links to other nodes in the file don’t work, only external links. The links to other nodes work when I open the file directly in FigJam.
I am using the link as you mentioned (without any node selected).
emi.rusakova1
Sep 16, 2024 3:58 PM UTC
Hello. I have the same problem. I tried to insert a link to my Telegram in a button in the Figma prototype. It works within Figma, but it doesn’t click on Behance when using the embedded code.
CHIARA COSTA
Jan 16, 2025 7:15 PM UTC
Hello everyone, I’m having the same issue. Any solutions?
Thank you
rashmi.koushik
Jun 9, 2025 1:59 PM UTC
Hello. I am facing the same issue! I’ve designed and built my portfolio in Figma, and I’ve embedded it on Behance. The links work on edit mode. But soon after the project is published, they don’t. Not sure how to change the url as described in the comments to make it work. Please suggest.
avnipal
Jul 7, 2025 8:15 AM UTC
Hi, I am facing the same issue and the problem has not been resolved yet.
martina.dujmusic
Oct 27, 2025 6:50 PM UTC
Hi, I am facing the same issue. Is there a solution for it?
TRESA ROSE ANOOP BDes23-27
Mar 5, 2026 3:50 AM UTC
Hi, I am facing the same problem , has anyone figured out a solution yet?
