Yezgi_Baha
Apr 8, 2024 6:27 PM UTC
Ability to add/remove/re-order items in an auto-layout component
This is a reference to a topic that was closed without resolution:
I can’t express how frustrating it is when a designer has to detach one of your components simply to add a tab in-between existing tabs or a dropdown option above existing ones.
When I build a component I shouldn’t have to create 10 hidden layers as placeholders to make sure that the component works for a design with 2 dropdown options or 10 options. I should be able to include 1-2 items in the component and let designers add/remove more from there.
Lack or re-ordering capability combined with the lack of add/remove capability for items in an auto-layout component means our components continue to get detached shortly after use. It defeats the purpose of maintaining a component library. It becomes a template library instead.
    Michael_Wandelmaier
    Feb 12, 2025 12:12 AM UTC
    Couldn’t agree more. This is the single biggest blocker to using Figma design systems for larger, more complex components and patterns.
    Dorothy Ryan
    Mar 18, 2025 6:08 PM UTC
    Can we vote this up? This is a really annoying limitation of components.
    Yezgi_Baha
    Apr 18, 2025 7:30 PM UTC
    ​@Figma_Team any inputs?
    leeharrisonmellor
    Apr 29, 2025 9:33 AM UTC
    This is a really annoying aspect of Figma. It’s a major blocker for complex components. For example, I have an RTE organism that sits within several components. The RTE contains rows of different heading/type/bullet/list styles that the designers need to be able to change the order of to build designs/prototypes. Having to detach the components creates havoc when you then try and create variations of the designs, relying on variables to resize/recolour the components.
    How do other users deal with this headache?
    Chris_Gatland
    Apr 30, 2025 1:17 PM UTC
    Agreed 100%.  I frequently end up having to detach my own instances because the alternative would take too much repetitive editing.
    Imagine the scenario - you have a 7 item menu and you realise you need to add a new item at the top.  To achieve this, you either need to detach and hack the instance or you have to rewrite all of the text strings and re-assign icons to every list item (assuming you even have another dummy item at the bottom to unhide).
    I pretty often need to re-order menu items between design concept and final spec as the product evolves.  It should be a trivial task.
    Gerlof
    May 1, 2025 7:49 AM UTC
    This would be so great to have
    Lee Costic
    May 12, 2025 3:18 PM UTC
    Reorder objects in an autolayout component instance. Allow for order overrides. Allow users to reorder (drag or arrow) objects inside a component instance that has auto-layout on it. Especially useful for components that have repeated elements, such as a dropdown menu or a group of form inputs, navigation. This would be much quicker than manually changing each of the elements in-between where the current element is and where the new position is. Or for users that don’t have patience and break…
    Agree with all comments here, I run into this at least once a week, very frustrating limitation. (I initially thought this was just a setting our component library architects had forgotten to enable, but no...it’s an actual Figma limitation!)
    Thoughts on this ​@seni ​@dvaliao @Celine_ ?
    Sebastian_Holzki
    May 14, 2025 1:33 PM UTC
    Has there been any movement on that front? It’s a big limitation for design systems and using them
    Kevin_Voller
    May 22, 2025 5:29 PM UTC
    +1 – This would be a great feature. In theory it could be implemented as a component property, controllable both in the canvas area and in the properties panel where it’d be reflected – drag and drop to reorder maybe?
    Jessica12
    May 23, 2025 2:42 PM UTC
    Running into this problem right now in our design system. It would be so much better if I could just reorder in the Asset rather than breaking it to do so.
