djvSolution
May 29, 2024 11:56 PM UTC
Hey All, sorry for the lack of acknowledgement here!
Back in 2022, when the 1st topic was shared, the forum was primarily run by the community. With that being said, this a feature limitation at the moment, due to how a Frame keeps its size from a Main Component, once it no longer has any content within it. There is no guarantee on if or when the team will improve upon this behavior.
There’s a bit of a workaround you can do with a Group, but it does cause issues where the Group isn’t taking up space like a Frame. But it will create the space between objects to be there.
In these types of situations, the only true workaround for this would be to add a Component Property that has the Frame hidden entirely, or depending on your design, you can make variants.
The workaround may vary depending on your file, so if this doesn’t help, please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to your file, and share edit access with support-share@figma.com, so the team can take a closer look.
May 13, 2026 6:04 PM UTC
Hi ​@Sondeeer, thanks for reaching out!
I’ve merged your topic with this similar, existing one in the community. I understand why this i slowing down your workflow, but this a feature limitation, due to how a Frame keeps its size from main components, once it no longer has any content within it. As I already mentioned above, there is no guarantee on if or when the team will improve upon this behavior.
There’s a temporary solution you can try with a Group, but it does cause issues where the Group won’t take up space like a Frame. But it will create the space between objects to be there.
In these types of situations, your best option would be adding a Component Property that has the Frame hidden entirely, or depending on your design, you can make variants.
The temporary solution may vary depending on your file, so if these recommendations don’t help, please reach out to the support team directly for guidance.
