XavierLagriffe
Jun 26, 2026 2:14 PM UTC
Video stays frozen on first frame in Figma Motion preview and MP4 export, even as a separate layer
Hi everyone,
I’m testing the new Figma Motion feature and everything feels very intuitive so far, but I’m running into an issue with video playback.
The Motion animation itself works correctly, but any video used inside the animated frame stays frozen on its first frame. This happens both in the Motion preview and in the exported MP4.
At first, I thought the issue might be related to using the video as a background fill. However, I also tried placing the video as its own separate layer/object inside the frame, and the result is the same: the video still does not play. It remains frozen on the first frame.
So the issue does not seem to be related to the video being used as a background. It seems more like Figma Motion is treating video fills/video layers as static images.
What I have checked so far:
  • The video is inside the animated frame.
  • The video was tested both as a background fill and as a separate layer/object.
  • The Motion keyframes work correctly.
  • The issue happens both in the Motion preview and after exporting to MP4.
  • The exported MP4 contains the Motion animation, but the video itself remains static on the first frame.
  • The video file is imported correctly in Figma and appears as a video layer/fill.
Has anyone else experienced this with Figma Motion?
Are videos currently supported inside Figma Motion animations, or are video fills rendered as static images for now?
Is there any known workaround to make an embedded video play during Motion preview and MP4 export?
Environment/details:
  • Figma Motion
  • Export format: MP4
  • Video tested as: background fill and separate layer/object
  • Video format: [MP4]
  • Video codec, if known: [H.264]
  • Export size: [1080x1350]
  • Frame rate: [30 fps]
  • App/browser: [Figma desktop]
  • OS: [macOS]
For now, my workaround would be to export the Figma Motion animation separately and composite it with the original video in an external video editor, but I’d really like to know if this is supposed to work natively inside Figma Motion.
Thanks!
Jaycee Lewis
Jun 26, 2026 4:30 PM UTC
Hey ​@XavierLagriffe 👋 Thank you very much for the detailed write up. I’d like to get this onto support. Would you be able to share, in the support ticket, the following?
I figure the answer is yes and I don’t want to assume 😊Talk soon! — Jaycee
XavierLagriffe
Jun 26, 2026 8:34 PM UTC
Hi Jaycee,
Thank you very much for your help!
Yes, absolutely. I already have the screen recording showing the issue, as well as the exported MP4 where the problem is visible. My return include both files, along with the Figma file link shared with View access to support-share@figma.com.
For context, the issue is reproducible on my side: the Motion animation works, but the embedded video stays frozen on its first frame both in the Motion preview and in the exported MP4. I tested the video both as a background fill and as a separate layer/object, and the result is the same.
Thanks for escalating this to support.
Talk soon,
Xavier
Jaycee Lewis
Jun 26, 2026 10:04 PM UTC
Hey ​@XavierLagriffe 👋 Thanks again! I opened a support ticket for us. The ID is 1985529 and the subject line is Follow up from Figma Support. Please make sure to check your email inbox and spam filter for the ticket and any replies. I truly appreciate you taking the time to put all these details together. Have an amazing weekend! — Jaycee
YEO_Danielle
Jul 1, 2026 1:21 PM UTC
Thank you for flagging this Xavier, i’ve ran into the same issue!
Any updates ​@Jaycee Lewis?
Lauge Petersen
Jul 1, 2026 2:06 PM UTC
Same here.
Jaycee Lewis
Jul 1, 2026 7:01 PM UTC
Hey ​@Lauge Petersen and ​@YEO_Danielle I’ll add an update as soon I see one 😊 ​@XavierLagriffe thank you for the reply on your support ticket. I increased the priority on it just now. Make sure eep an eye on your inbox for any requests or replies from our Technical Quality team. Talk soon! — Jaycee
Maura Benitez
Jul 3, 2026 4:25 PM UTC
Hi,
Im having the same problem, and I would probably have to also export the Figma Motion animation separately and composite it with the original video in an external video editor, but already spent a lot of time working on this project in figma motion  :(
roxanagon
Jul 6, 2026 11:55 AM UTC
Hi ​@Jaycee Lewis
I’m running into the exact same issue with Figma Motion right now. I’m currently right in the middle of an active client project and trying to plan our next steps. Could you share an estimated timeline on when this might be fixed? It would help me immensely to know if I should wait for a Figma update or if it’s better to temporarily pivot to another tool for this specific animation.
Thanks so much for bumping the priority on this and for your help! 🙌
Jaycee Lewis
Jul 6, 2026 7:07 PM UTC
Hey, ​@roxanagon  ​@Maura Benitez  would either or both of you be able to grab a not-zoomed-in screen recording of this happening? I’d like to get support tickets for all in this thread open so we can track impact. Talk soon! — Jaycee
Brooke Worthan
Jul 6, 2026 11:12 PM UTC
Hi ​@Jaycee Lewis, I am also having the same problem. Can I also be updated on this issue? I am working on a workflow for a current project. I would like to keep most of the process all in figma.
