Weirdo
Apr 24, 2024 9:32 AM UTC
Variables for text styles make the file really slow
I have a big file (130K layers) and recently I add the new variables for text styles and boy the file running very slow, I can’t edit nothing, not mentioning play with the prototype.
It has nothing to do with my PC or memory usage (14%). I had to remove the variables for text styles to make the file run faster and it works.
This new feature is great but until this performance issue will not be resolved I will not add variables for text styles to my projects.
ksn
ksnSolution
Jan 15, 2025 7:18 PM UTC
Hey all - I know this has been a pain point for you, and I do want you to know I am hearing you.
From my end, I don’t have an update -- after the original issue with the text styles was addressed, any lingering/newer reports were determined to be part of a separate issue, and file review would be the best option in identifying the problem for everyone’s unique instance.
With that said, my best recommendation now is to do the following:
  • Share edit access to the file[s] you continue to have issues on with support-share@figma.com (you won’t be billed for this).
  • File a support ticket here if you have not yet done so.
  • When filing the ticket, please include the exact names of the files you have shared to expedite the investigation process
I’m going to close this topic since it is older + the original issue was resolved. If anyone who comes across this is experiencing any issues you believe are related, please create a new forum topic. Appreciate your understanding!
ksn
May 1, 2024 8:40 PM UTC
Can everyone here try restarting/reloading your Figma tab/file (or just hard resetting the app/browser window) and see if this seems fixed? Engineering believes that this has been mitigated, but want to confirm.
If you’re still having issues, let me know in a reply here.
Martin_Hill
May 2, 2024 7:14 AM UTC
Are we simply turning off and on again to initiate an update/fix? Or are you simply saying the solution is to turn it off and on again?
Gareth
May 2, 2024 9:32 AM UTC
Can confirm this has now been resolved on my side. Thanks to the team for the speedy fix, it was pretty bad!
May 2, 2024 9:47 AM UTC
Hey everyone!
I am Celine and I am working closely with Kim.
Thanks @Gareth for letting us know, glad to hear it works now 🙂
@Martin_Hill , yes please just refresh the tab (or force-quit and open Figma in a new browser window, or force-quit the Figma Desktop app and restart it.) Thank you!
Weirdo
WeirdoAuthor
May 2, 2024 12:04 PM UTC
Unfortunately, after I reload the tab, app and PC - on my side it is still pretty bad.
Deleting objects takes few seconds, prototype does not work at all (freezes) and overall navigation in the app is slow.
I’m using the desktop app and tried it with chrome and still no difference. Also switched from my work PC to my home PC which is a beast, and got the same slow performance.
ksn
May 2, 2024 2:13 PM UTC
Got it - thank you @Weirdo – I sent your message over to the engineering team. It does look like there’s still work that needs to be done.
For anyone else that sees this message from me:
If you could still let me know if things are still slow OR if things seem fixed for you, I would appreciate it. If you could also include what OS + browser version + app version you’re using, that would be immensely helpful as well.
Weirdo
WeirdoAuthor
May 2, 2024 2:29 PM UTC
I’m using:
  • Win10 22H2, Home
  • Chrome v124.0.6367.118
  • App v116.18.6
Martin_Hill
May 2, 2024 2:33 PM UTC
Still having the same slow issues here. I have a test file if you would like it still?
OS Mac Ventura version 13.6.6
Figma Desktop app version 116.18.6
FYI: the copy/pasting & duplicating of text styles is a pain.
ksn
May 2, 2024 3:41 PM UTC
@Martin_Hill Yes please – can you share edit access to it with support-share@figma.com, and then let me know the name of it? You can PM it to me if you’d prefer.
Astrid_Boivin
May 3, 2024 5:11 PM UTC
Hi,
I cleaned the app cache and restarded and reloaded tabs, but it’s still slow on my side as well. The file is linked to the library using the variables for font familiy and style, modifying text or editing components is slow and delayed when variables are used. This file only has one basic frame in it 😕 (file is already shared with support team)
I do not encounter this slowness on my other files which are considerably bigger than this one when using the library that doesn’t have the variables for text.
I’m using the desktop app (116.18.6) on Windows 11 (22h2 Entreprise)
