Patrick_Cusack
Dec 2, 2025 11:36 AM UTC
Unable to Remove Unused or Auto-Generated Figma Slides Styles
Hi Figma Support team,
I’m running into an issue with unwanted colours appearing in the Design-mode colour picker in Figma Slides, and I’m hoping to understand whether this is expected behaviour or a limitation.
Summary of the issue
Even after fully cleaning my Slides template so that every element uses only my defined template colour variables, the colour picker in Design mode still shows many extra custom colours that are not used anywhere in the file. These appear to be leftover colours that were automatically created when pasting designs from regular Figma Design files into a Slides file.
What I’ve tried
  • I replaced all existing colours with my new template colours
  • I verified that none of the stray colours are used in any layer, component, or style.
  • I also confirmed that this only affects Design mode, not Slides mode, where only the correct template variables appear.
The core problem
These extra colours appear to be orphaned, auto-generated colours with no UI to remove them, even when they’re completely unused. They clutter the colour picker and make it difficult to maintain a clean colour system inside a Slides template.
Expected behaviour
  • If a colour is unused and not part of a Slides theme, it should be possible to delete it.
  • Or at least, unused colours should not appear in the Design-mode colour picker.
Current behaviour
  • Stray colours persist indefinitely.
  • They appear only in Design mode, creating visual clutter.
  • They seem to originate from copy/paste actions from Design files.
Impact
This makes it difficult to maintain a clean colour system for a shared Slides template. These lingering colours introduce confusion and inconsistency when designing inside Slides.
Questions
  1. Is there currently a way to delete or reset unused or auto-generated colours in Slides?
  2. Is this behaviour expected, and are there plans to give users more control over colour management in Slides?
  3. Is there a recommended workflow to avoid these stray colours appearing in the first place?
Thanks so much!
Colours look fine in Slides Mode
Loads of stray messy colours in Design Mode that can’t be removed
Margot_Gabel
Mar 27, 2026 1:41 PM UTC
Figma Slides template management is just non-sensical UX at this point (with so many bugs that I’ve been reporting many times..) and yet Slides has received zero improvements whatsoever in more than a year.
( We just continue using it because Powerpoint and Google Slides are still 10 times worse 🤷‍♀️ )
Using Figma since 2018.
Gail Barlow
Mar 27, 2026 2:25 PM UTC
Same - it’s worse than ever. We’re moving back to Google slides, even though we can’t use custom fonts in slides, having those is not worth the nightmare of Figma’s half baked slides function
carlyschon
Mar 27, 2026 3:17 PM UTC
Having this issue right now with colors also—it’s just the same two colors labeled “custom style” over and over again burying my actual template miles down the list
Mar 27, 2026 6:32 PM UTC
Hey All, thanks for continuing to share your feedback!
We appreciate you flagging this and sharing how it’s impacting your workflows. I completely understand how frustrating this can be, especially when it slows things down in practice. This is still something our Slides team is aware of and actively tracking.
While I don’t have any new updates to share just yet, I’ve passed along the recent feedback here to help reinforce the impact and priority. As soon as I hear more on potential improvements, I’ll be sure to update this thread. Thanks again for your patience and for continuing to surface these details. It’s genuinely helpful for the Slides team.
Mar 27, 2026 6:35 PM UTC
Hey All, thanks for sharing your feedback!
I hear you, and I completely understand how this has been impacting your workflows. Rest assured, this is still something our Slides team is aware of and actively tracking.
While I don’t have any new updates to share just yet, I’ve passed along your feedback to the Slides team to help reinforce the impact and priority. As soon as I hear more on potential improvements, I’ll be sure to update this thread. Thanks again for your patience and understanding.
Philippe_Cao
Apr 8, 2026 4:21 PM UTC
Big +1. This is such a huge pain and makes templates (what should be a core feature) almost unusable in Slides –  copying and pasting content from different places to assemble decks is a very common workflow. Today, doing so makes it extremely difficult to cleanly manage the styling of a deck.
Thomas Whitehead
Jun 24, 2026 4:42 PM UTC
Slides is potentially such a good product,
Our team loves the grid layout, auto-layout and being able to utilise all our library assets – it is the difference between our organisation needing 5 and 30 Figma seats, far more so than any Ai feature – but this issue makes it impossible to manage all our decks at the scale we need.
Sam_O_Leary
Jul 3, 2026 6:15 PM UTC
Have you ever been in slides and had the problem of 1000% different style templates cluttering up your deck?
Well quit hitting your head against your desk because we have a solution for you! (unofficial but tested!)
1: Copy all your slides into a Figma Design file
2: This is an opportunity to double check all your type and colour styles and remove any duplicates or things that are slightly off, or near to finalised colours for eg.
3: Copy all your final frames into a new slides deck. Et voila! There should now be one single style template present in this fresh Slides deck.
Why does this happen in the first place you might be asking?
When you copy from multiple sources, multiple  presentation decks, various figma design files, those styles are carried over and given their own style template. So you can see how if multiple people are pulling in from multiple sources things can get out of hand pretty quickly.
From here you can refine your type and color variables much more easily.
The single source copy paste seems to solved the issue for us!
Good luck out there!
Margot_Gabel
Jul 7, 2026 11:42 AM UTC
Interesting workaround ​@Sam_O_Leary thanks for sharing!!
LucasRhys
Jul 13, 2026 10:17 AM UTC
​@djv has there been any update to this? Our company slides are falling apart with a spam of different colour styles that have been brought in - and the team is getting really frustrated with our move to figma slides - I can’t believe how much updates have slowed
