Adam_Gordon
May 3, 2024 11:45 AM UTC
Typography/Size Variables: Styles don't respect applied mode for variables
When applying text styles that have associated variables attached the values presented do not respect the applied mode. For instance I have a title that has a mode for Mobile (20px), and a mode for TV (40px), when i open up the style, the default mode (in this case mobile) is displayed instead of the TV mode size.
I have also observed this within grid layouts when applied it shows the default mode (26 columns). When in reality it is actually 24 columns, if you then detach the style it shows the correct number.
And when detached you can see it shows the correct value
Seems this was a major oversight, as it makes applying size variables pretty time consuming, as I have to check if I’ve chosen the correct size by clicking and opening up the variable list.
In short it seems to default to the first default mode, instead of respecting the chosen mode. It also only seems to affect styles.
Anyone else found this to be an issue?
Meet_Shah
Oct 14, 2024 12:07 AM UTC
Hey team, when can we expect a solution to this? This is super important as I’m working on a bi-lingual interface and this is super important.
Nicolas_Prieto
Oct 18, 2024 1:02 PM UTC
Hey, running trough the same issue at the moment. Is there any update on this? cc @dvaliao
Infectedcell
Nov 1, 2024 4:19 PM UTC
Hey!
Any news regarding this issue? It is already 6 mnths passed but the problem still exists.
Is there any workaround at this moment from Figma team?
rvx
Jan 31, 2025 1:31 PM UTC
The issue still remains very much unsolved.
It’s been 8 months since it has been on the “team’s radar”. Seeing how variables and styles are an integral part of software, I’m really hoping to hear an update on this soon.
Cheers.
hummh
Feb 7, 2025 9:44 AM UTC
I am wondering how Figma can say variables are out of beta (aka production ready), but at the same time important things are missing:
  • Wrong variable preview
  • No library swapping support
Why is the ticket marked as “solved”?
Feb 7, 2025 4:11 PM UTC
Sorry for the confusion, ​@hummh!
My reply was marked as the best answer since it’s the only one so far with direct buy in from our Typography team.
While I wish I had an actual update to share, this is not high priority on the team’s current pipeline. It is on the team’s radar to improve in the future, but there is no specific timeline we can share on when/if variable preview will be rebuilt to include modes for typography variables or library swapping support.
Stephen_Howe
Mar 3, 2025 10:49 AM UTC
That’s what is wrong with Figma, while customers are paying a lot of money Figma focusses on all the wrong items it seems.  All of these things are base functionalities for design systems and instead of putting focus on a new UI, Figma should focus on those base functionalities again.  For example we have designers in our company which use our central design system but they keep seeing the values from the default mode instead of the selected one.  One of the reasons why designers need to invest time in plugins like tokens studio because Figma seems to forget what Figma was built for!!! Nowadays we need so much workarounds in Figma, design systems should be their core focus!  We don’t care how styles and variables where built and that it’s difficult to fix, just make base functionality work!
Jason Pamental
May 20, 2025 5:50 PM UTC
So ​@dvaliao how do we bring more attention to this issue? We’re using variable modes (driven by Token Studio) to create type styles (in addition to the modes setting spacing, border radius, etc), and having to explain to designers that what they see in the style menu in the right sidebar is not accurate seems to be a pretty big miss. If that’s also going to be true about spacing, border radius, padding, etc then the frustrations with the broader design team are only going to compound.
Clearly there are a lot of folks frustrated by this; how do we help elevate this priority?
Corey Mcclelland
May 21, 2025 2:23 PM UTC
​@dvaliao My enterprise design system team is having this same issue and it has quickly become a blocker. Our executive reviews require accurate type and our engineers require accurate token references. We are having to detach type and manually override to display the correct styles even though the values are accurate.
This is a high-priority item for our team! How can we get this prioritized?
May 21, 2025 10:16 PM UTC
Hey All, thanks for your continued feedback!
I’ve flagged this topic again to the team to advocate for its prioritization in the their future pipeline.
