teo.kang
Apr 13, 2025 4:35 PM UTC
The issue where the height value automatically changes from "Fixed" to "Hug" when combining duplicated components to apply a nested instance.
I want to solve the issue where the height value automatically changes from "Fixed" to "Hug" when combining (click create component set) duplicated components to apply a nested instance.
That issue actually occurs even before applying a nested instance—just grouping the components triggers it. When I manually change the height from "Hug" to "Fixed" after combining the group, the size options defined in the original parent component no longer work as intended.
[before combine components]
buttons height is fixed (56)
[after combine components]
buttons height state is change with hug
Raphael_M
Power Member
Apr 14, 2025 1:57 AM UTC
I’m wondering where did your padding go? I think the instance was wrapped again so you can make it into another component. Check your layers
