Josua
Mar 21, 2026 10:42 AM UTC
Some elements in a slot do not show hover state in prototype preview
👋🏻 Hi guys,
I’ve run into what seems like a bug while working with the new slots feature in Figma components, and I’m curious if anyone else has experienced this.
I’m currently implementing slots in my components and really like the concept so far. However, I’m facing an issue that makes the feature unreliable for my use case.
The issue:
Sometimes (not consistently), when I place a component with a hover interaction into a slot and preview the frame, the hover states inside that slot don’t trigger at all.
Possible pattern I noticed:
  • The issue seems more likely when using multiple slots within a single component
  • For example, in a navigation bar with dynamic content on both the left and right sides (two separate slots), the hover states in the second slot often don’t work in preview
Additional observation:
  • If I place placeholder elements (with hover states) inside the slot in the main component, those hover interactions usually don’t work
  • When I then insert the component as an instance and add new elements into the slot, only the hover states of the newly added elements (inside the instance) work — not the ones defined in the parent component
This behavior feels inconsistent and makes it hard to rely on slots for interactive components.
Has anyone experienced something similar or found a workaround?
Thanks in advance!
Celyn_L
Celyn_LSolution
May 14, 2026 5:19 AM UTC
Hi everyone, thanks so much for your patience here.
We’ve now rolled out a fix, and this issue should be resolved.
Could you please try the following steps to see if it resolves things on your end?
  • Reload your tab or Figma client
  • For any problematic slots, try regenerating the affected instances or clicking into them to refresh
These should update the instances and help apply the fix.
If you’re still seeing the issue after trying this, feel free to share a quick screen recording and we can take a closer look 🙌
Celyn_L
Celyn_LSolution
