Josua
Mar 21, 2026 10:42 AM UTC
Some elements in a slot do not show hover state in prototype preview
👋🏻 Hi guys,
I’ve run into what seems like a bug while working with the new slots feature in Figma components, and I’m curious if anyone else has experienced this.
I’m currently implementing slots in my components and really like the concept so far. However, I’m facing an issue that makes the feature unreliable for my use case.
The issue:
Sometimes (not consistently), when I place a component with a hover interaction into a slot and preview the frame, the hover states inside that slot don’t trigger at all.
Possible pattern I noticed:
  • The issue seems more likely when using multiple slots within a single component
  • For example, in a navigation bar with dynamic content on both the left and right sides (two separate slots), the hover states in the second slot often don’t work in preview
Additional observation:
  • If I place placeholder elements (with hover states) inside the slot in the main component, those hover interactions usually don’t work
  • When I then insert the component as an instance and add new elements into the slot, only the hover states of the newly added elements (inside the instance) work — not the ones defined in the parent component
This behavior feels inconsistent and makes it hard to rely on slots for interactive components.
Has anyone experienced something similar or found a workaround?
Thanks in advance!
Celyn_L
Celyn_LSolution
May 14, 2026 5:19 AM UTC
Hi everyone, thanks so much for your patience here.
We’ve now rolled out a fix, and this issue should be resolved.
Could you please try the following steps to see if it resolves things on your end?
  • Reload your tab or Figma client
  • For any problematic slots, try regenerating the affected instances or clicking into them to refresh
These should update the instances and help apply the fix.
If you’re still seeing the issue after trying this, feel free to share a quick screen recording and we can take a closer look 🙌
Rubem_Pechansky
Apr 7, 2026 3:10 PM UTC
I also have stumbled into this in a recent project. Because of those problems I decided to give up using slots in some frames. But there is also another problem, maybe they are related. Some contents inside auto-layout slots refuse to resize themselves in prototype mode. I’ve just submitted ticket #1834908 and shared the file with support-share@figma.com as described above.
Apr 7, 2026 7:51 PM UTC
Hi ​@Rubem_Pechansky, thanks for chiming in here!
I completely understand your frustration with this. I’ve confirmed that the team has received your ticket and file share, and I’ve escalated your ticket on your behalf so they can investigate this for you on priority.
The team will review and be in touch as soon as possible.
Miles Roxas
Apr 12, 2026 3:58 PM UTC
has this been resolved? Still not working for me...
Tom Reem
Apr 12, 2026 9:46 PM UTC
Hey ​@Miles Roxas — thanks for adding your experience here, and sorry to hear this is affecting your workflow, too.
I checked in on this and our Engineering team is still actively investigating. To help move things along, it would be really useful for us to look at a specific file where this is happening. I've sent you an email with next steps on sharing access securely. If you're able to provide that, it would go a long way. Check your inbox for your case number: 1845148, and we'll go from there. 🙏🏻
If anything else comes up, don't hesitate to reach out.
Rubem_Pechansky
Apr 23, 2026 6:48 PM UTC
Follow-up: this specific issue is probably fixed. For those who have this problem, you’ll have to run the command “Regenerate All Instances” from Actions, then edit or add something just to save your Figma file. After that, the problem seems to be gone. Hope this works for you guys too.
Celyn_L
Apr 24, 2026 2:44 AM UTC
Hey ​@Rubem_Pechansky, really appreciate you taking the time to share this workaround.
I’m glad to hear that resolved it on your end, I’ll pass this along to the team as well.
If anyone else is still encountering this issue after trying this, feel free to share a file link so we can take a closer look.
Thanks again for sharing this 🙌
Etienne Barbedette
May 8, 2026 12:55 PM UTC
Same issue here… doesn't seem to have been resolved
adamsmasher
May 9, 2026 6:28 PM UTC
Hi, ​@Etienne Barbedette - thanks for posting, and sorry to hear that you’re still seeing this.
I just checked again on our end and it looks like the fix isn’t out yet. While I don’t have a specific ETA for the release of it, you might want to try the suggested temporary solution by ​@Rubem_Pechansky from earlier in the thread as that seems to have helped in the interim:
Thanks for your patience!
Etienne Barbedette
May 11, 2026 9:00 AM UTC
I tried, but it didn’t work for me.
May 11, 2026 6:42 PM UTC
Thanks for following up, ​@Etienne Barbedette!
I appreciate your patience here. I can see how this issue is disrupting your workflow, especially with the temporary solution not working as expected for you. I understand how frustrating that can be.
Our team is still actively investigating and working toward a proper fix. As soon as it’s available, we’ll share an update right away.
Thanks again for sticking with us while we get this resolved.
