Celine_Solution
Aug 6, 2026 2:44 PM UTC
Hey ​@Eniola Orunto , Celine from the Figma Community Support team here.
You can connect the Figma MCP server in two ways:
  • Remote MCP server (preferred): Connects directly to Figma’s hosted endpoint at https://mcp.figma.com/mcp. You can learn how to install the remote MCP server.
  • Desktop MCP server:  For this option, please make sure you have toggled to the Dev Mode, then check in the right panel, click ‘Enable MCP Server’.
The Desktop MCP server runs locally through the Figma desktop app. You can learn in this article how to install the desktop MCP server. The desktop MCP server is primarily for specific use cases for organizations and enterprises. For the broadest set of features, we recommend using the remote MCP server.
If you are still running into issues after trying these steps, please reach out directly to our support team so they can take a closer look at your case and settings. To do that, go to the Support Hub / Type “Report a bug, Contact Agent” / Click Start a chat / Select Enter and follow the prompts. Thank you!
Celine_Solution
sanze
Aug 26, 2026 1:43 PM UTC
After spending hours searching, I finally found the solution. Here are the steps:
  • Make sure Dev Mode is enabled (this requires the appropriate paid plan).
  • Click the Figma logo in the top-left corner, then select Actions (or press Cmd + K).
  • Type “enable”, and you should see the “Enable Desktop MCP Server” option.
  • Select it manually to enable the server.
