HeatherSimpsonMayfield
May 20, 2026 9:45 AM UTC
Make Kit - No components were extracted from this library
I have a design library with styles, tokens, variables, components etc all set up and published.
I’m trying to use this to create a kit in Figma Make but when I choose the design library, when I click in the components folder, it says ‘no components were extracted from this library’ and I don’t know why.
Yogesh Arora
Jul 15, 2026 4:05 PM UTC
Hey ​@Jaycee Lewis
I am kind of in the same boat. But the experience is a bit confusing here for me. Am attaching a screenshot for that explanation.
  1. I am doing a POC with Carbon design system
  2. Published it and create a kit using “Library style”
  3. I dont see any components from Carbon in the Components folder as such, but when i tried building a page, i checked the code for that page and there in, it refers to components being imported from Carbon/React.
Is it the case that, the components are not shown as such in any folder, but when we build, if a page is using any, it will simply import those components via code.
Could this be confirmed? Bigger question of course is, if we just create a Make kit using “LIbrary Styles” are the components by default also accessible OR these could be accessible only through “NPM Package” route.
Jaycee Lewis
Jul 22, 2026 5:09 PM UTC
Hi, ​@Yogesh Arora 👋 Let me do some digging for us and I’ll try to follow up here by the end of the week. Thanks! — Jaycee
Jaycee Lewis
Jul 22, 2026 5:41 PM UTC
Hey ​@Yogesh Arora  👋 Great question — and observation.
When you create a kit using "Library Styles," Figma Make extracts your library's CSS styles — colors, typography, spacing, and tokens — and delivers them as a styles.css file inside the kit. It does not extract your components. That's why you don't see a Carbon components folder in the kit.
So to your bigger question: components are not accessible by default through the Library Styles route. To bring in actual components, you need the NPM Package route.
- Library Styles → styles and tokens (styles.css + guidelines)
- NPM Package → the actual production components
Basically, code components come through the npm package route while styles/tokens come through the library.
Docs for reference:
Please let me know if you need any additional help! — Jaycee
Yogesh Arora
Aug 11, 2026 8:42 AM UTC
Hello ​@Jaycee Lewis
Thanks for the response. A question:
How can i install a Design system, which i have purchased through a license, I am guessing thats not a simple process perhaps as you mentioned through NPM package. The one in above thread was Carbon, which is open sourced, so was easy for Figma Make to fetch online.
Jaycee Lewis
Aug 13, 2026 8:32 PM UTC
Hi, ​@Yogesh Arora 👋 Thanks again for the great question and follow up.
I need to update my previous reply — the @carbon/react imports you saw weren't your Library Styles kit delivering components. In Figma Make, "the model can install and use npm packages on your behalf as it builds your application" (Working with npm)
Library Styles genuinely only brings styles. If you check the code view, your library folder contains a guidelines folder and a styles.css file, nothing more — see the "How do I know what the Make kit is using from my library?" FAQ in Get started with Make kits.
A licensed system usually isn't on the public registry, and Make can't pull it the same way.
Two questions:
  • How does your vendor distribute it — public npm, a private registry with an auth token, or a tarball?
  • What plan are you on? Publishing to Figma's private npm registry runs through Admin → Resources → npm registry, and scope management needs an admin
Thanks! — Jaycee
