KrisLGX
Jul 9, 2026 11:41 AM UTC
Make kit feature
Hi Figma team,
I have a question about the difference between the Make Kit implementation that was presented during Schema 2025 and what is currently available.
From the Schema presentation, it looked like the workflow was:
  • Export an existing Figma library directly to Make.
  • Make automatically converts the design system into React components and CSS.
  • A Component Showcase is generated where you can browse all imported components and variants.
  • You can open an individual component, view its generated code alongside a live preview, and use prompts to add interactivity (for example, changing the cursor on hover or creating animations). Prompts are scoped to the selected component.
However, the current Make Kit implementation described in the documentation seems to focus on creating and configuring a Make Kit manually, rather than importing an existing design system and getting a generated React component library with a Component Showcase.
Am I misunderstanding the feature, or has the implementation changed since the Schema presentation? Is the automatic library-to-React conversion and Component Showcase still planned, or was that demo showing functionality that isn’t available yet?
I’m mainly trying to understand whether the current Make Kit experience is the same product that was demonstrated at Schema, or if it has evolved into a different workflow.
adamsmasher
Jul 9, 2026 4:39 PM UTC
Great question, ​@KrisLGX - thank you for asking, and totally understandable why you’d want to get clarification.
Out of curiosity, have you tried making a kit yet just to test out the experience? Make has evolved since it was first announced, but it’s still generally the same intent and goal of helping others get started more quickly without having to start from scratch. Having said that, I’ll address each of your points individually just to be a bit more succinct:
    • You can do this with either NPM packages or with an existing Figma library by choosing the  Assemble your kit option after choosing to create a kit. The alternative is the Start from scratch option, where you prompt make to build components and assets itself.
    • There’s a bit of nuance here depending on which of the options you chose when first creating the kit. If you assemble it and import an existing library or NPM package, Make won’t need to do this unless you want to create additional components and assets for the kit. If you are starting from scratch, then it does create this as needed to create the kit. Regardless of which you choose, Make will use the contents of the kit to guide it in making components and CSS in other Make files.
    • I’m glad you asked about this one - we’re still working on this at the moment. Stay tuned!
    • This works while editing a kit similar to how it works when working with Make in general. As an example, I started a kit and imported a library, and then asked Make to create an example component using the library styles. I then clicked the Edit button at the bottom of the chat window, selected a part of the design, then clicked the Go to source button to view the code for that part of the component. In the chat window, the element is shown as selected and I can prompt changes which would not only change the component but also update the kit.
Does what I’ve said make sense for you? Let me know if you want more information on any particular point!
KrisLGX
KrisLGXAuthor
Jul 13, 2026 8:19 AM UTC
Thanks ​@adamsmasher for the detailed explanation, that definitely clears up a few things.
I’ve tried creating a kit from scratch, as we currently can’t import our component package because we don’t meet the requirements for that workflow. Most of my confusion came from the Schema presentation, which made it seem like the workflow was primarily focused on importing an existing design system into a Make kit. The current experience feels a bit different, so I wasn’t sure whether those capabilities had been postponed, changed, or are still on the roadmap.
It's good to hear that the Component Showcase is still in development, and the explanation of component editing and the Go to source flow makes sense.
One thing I'm still curious about is the recommended workflow when starting a kit from scratch. I've found documentation and guidance around writing guidelines, but I haven't found much information about building and evolving components through prompting.
As a designer rather than a developer, I find it difficult to assess whether the generated kit structure and components are actually being used as intended. In my experience, the outcome doesn't always match my expectations. This makes me hesitant to invest significant time and credits into building a kit, because I'm not always confident that the resulting components and structure will be reused consistently in downstream projects.
For example, I created a small test kit that only included our Dialog component. The resulting kit structure looked like this:
src
└── app
├── App.tsx
├── Dialog
│ ├── Dialog.tsx
│ └── UploadFileDialog.tsx
└── imports
├── Colours
├── Dialogs
├── index.tsx
├── svg-lxkvkzjsjj.ts
├── FontStyles
└── Icons
When I attached this kit to a new Make project and prompted it to create a dialog, it followed the .md guidelines from the kit, but it didn't appear to reuse the existing Dialog component. Instead, it generated a new dialog implementation from scratch.
Is this the expected behavior, or is there something I'm missing about how kits and component reuse currently work? Are there any guidelines or recommended approaches for building, organizing, and evolving components within a kit to achieve more consistent results?
KrisLGX
KrisLGXAuthor
Jul 16, 2026 7:54 AM UTC
Hi ​@adamsmasher , Would you mind taking a peek at the question above? I’m interested in learning the best practices on how to set up components for Figma Make kits.
adamsmasher
Jul 16, 2026 4:30 PM UTC
No problem at all, ​@KrisLGX, and thanks for tagging me so it didn’t fall through the cracks! This is a really great distinction to call out, actually. And just to make sure I’m understanding you correctly, you’re asking whether Make should be recreating a component or using an instance of it like Figma Design? For now, the expectation is Make will recreate the component from your Make kit, and this is where the guidelines in your kit can really help. As part of making your kit, I would prompt Make to generate guidelines. You can also add your own, though having Make create them first will save time and you can edit them yourself later. As an example, you can include in your guidelines instructing Make to use the code in the kit explicitly (in addition to how it uses it based on your guidelines).
For best practices in particular, I would see our guidelines for library styles and writing design system guidelines for Make kits help articles. The latter in particular will really get into what you are looking for, I think.
Regarding the overall experience, it’s evolved since Schema as we learn and iterate on what works best. Your feedback is super helpful for that, so thank you!
