t.los
Jun 26, 2025 5:28 AM UTC
Issue with MCP Server get_image and Google Gemini CLI
I tried Figma Dev Mode MCP server with GeminiCLI. Seems that the get_image Funktion can be called but Gemini reports an issue with saving the file
Do you know if it is a Figma Dev Mode MCP server issue or a Gemini CLI issue?
Bhaumin
Jun 27, 2025 5:50 AM UTC
Can you please share your part of gemini config in which you have added mcp server of figma?
t.los
t.losAuthor
Jun 27, 2025 8:16 AM UTC
My Gemini CLI Quickstart:
#gemini cli: for scripting and automation
#install
npm install -g @google/gemini-cli
#edit config
notepad %USERPROFILE%\.gemini\settings.json
#add github + figma mcp server
"mcpServers": {
"github": {
"command": "npx",
"args": [
"-y",
"@modelcontextprotocol/server-github"
"env": {
"GITHUB_PERSONAL_ACCESS_TOKEN": "${GITHUB_PERSONAL_ACCESS_TOKEN}"
"Figma Dev Mode MCP": {
"type": "sse",
"url": "http://127.0.0.1:3845/sse"
#start geminicli
gemini
#simple hello world
echo "create a python script with hello world, store in hello_world.py and execute that script. display the output. print what you are doing with enumeration" | gemini --yolo
Here is the plan:
1. Create the Python script `hello_world.py`.
2. Execute the script using the Python interpreter.
3. Display the output.Hello, World!
echo "create a python script with hello world, store in hello_world.py and execute that script. display the output. silent mode" | gemini --yolo
Hello, World
Coini
Dec 20, 2025 4:19 PM UTC
Im also encountering this exact issue
