Tasya58
Sep 5, 2025 8:00 PM UTC
hovering button
Hello, the while hovering button does not work. I made this component a week ago, the button worked. Now it does not. And when I delete previous slides/options and make it again, the same button is also not there. I tried to open it in the web version, it did not help.
Tom Reem
Sep 8, 2025 3:58 AM UTC
Hey ​@Tasya58 — welcome to Figma Forum, and thanks for flagging this. Sorry for the disruption this is causing. I went ahead and tried to recreate this behavior in a test file by setting up a “While hovering” interaction, but it worked as expected on my end. 🤔 Since I wasn’t able to replicate it, it would be helpful if you could confirm a few details so we can narrow things down:
  • the steps you took to set up the component in question
  • whether this is happening on the web or desktop version of Figma Design
  • if you’re on the Figma Desktop App, whether you’re running version 125.7.5 or later
  • if refreshing the tab makes any difference.
If the issue continues, our Technical Quality team can take a closer look at the file itself. To get that started, please fill out this form and include:
  1. the link to this Forum post for reference
  2. a link to the file where this is happening
  3. ‘can edit’ access granted to support-share@figma.com for the impacted file
  4. a screen recording showing the issue in action.
Appreciate you taking the time to surface this, and we’ll keep an eye out for your reply.
Tom Reem
Sep 10, 2025 9:58 PM UTC
Hi ​@Tasya58 — I’m following up on my open conversations and wanted to check in. Have you noticed any improvements, or are you still running into this issue? If you’re open to it, we’d love to take a closer look at the file where this is happening. When you have a moment, you can share more details through the secure form linked above. 🙏🏻
