_Alex
May 6, 2021 9:01 AM UTC
Hover state doesn't reset
I used hover to create button hover states, but since today it no longer resets to its original state when I stop hovering. I can mimic the intended use by using mouse enter and mouse leaves, but until today hover worked.
It also doesn’t reset when you open an overlay, it’ll remain in its “hover” state forever, even when using mouse enter/mouse leaves.
aksxs
May 7, 2021 6:50 AM UTC
I faced this problem too.
Eduardo_Faraday1
May 10, 2021 1:10 AM UTC
No just hover, it’s happening across many interactions from Prototype. Please Figma team fix this ASAP!!! 😞
Mateus_Freitas
May 10, 2021 2:38 PM UTC
Same here.
Vladimir
May 12, 2021 2:41 AM UTC
same, while hoverting state remains active
Aaron_Dolan
May 18, 2021 9:18 PM UTC
I am having this same issue with Variants, Mouse Enter works fine but then it will not change back When mouse leave. Any fix for this yet?
Mateus_Freitas
May 20, 2021 2:39 PM UTC
The bug continues to persist.
It needs to be fixed asap, ples.
May 26, 2021 9:50 AM UTC
I also faced a similar issue, and the workaround I found is to add 1 more interaction “Mouse out” on the hover variant, back to the Default variant.
Fred_Tinsel
May 28, 2021 9:10 AM UTC
I think I’ve got the same problem
Figma – 27 May 21
J.D_Compton
Jun 9, 2021 12:08 AM UTC
While hovering seems to work, but the reset back to the first state doesn’t animate back using the same animation set to get there and just snaps back. If we can make it retain the set animation state (custom or otherwise) when returning from the hover when the mouse leaves the hover area that’d be awesome, so I don’t have to make an extra 6 interactive states to use this with mouse enter/mouse leave.
mzanko
Sep 29, 2021 5:57 PM UTC
Hi there,
I just wanted to say that your tip changed a lot in my project! I was even thinking about not using the interaction at all in my project, so… thank you.
