Alex Xie
Feb 23, 2026 5:07 AM UTC
generate_figma_design not available in Claude Code connector?
The generate_figma_design tool — documented as "Claude Code only, remote only" in Figma's developer docs(https://developers.figma.com/docs/figma-mcp-server/tools-and-prompts/) — is not available in my Claude Code session despite the Code to Canvas feature being officially announced on Feb 17, 2026.
My setup:
  - Figma MCP remote server is connected and working (all other tools like get_design_context, get_screenshot, whoami etc. work fine)
  - Full seat on a Pro tier Figma plan
  - Figma desktop app is running
  - Claude connector browser shows Figma connector version 1.0.3
The tool simply isn't exposed in the tool list. Is this a version/rollout issue on the connector side, or are there additional requirements to access this tool?
Lacey Wright
Mar 20, 2026 8:42 PM UTC
This is incredibly frustrating. No matter what I do, I can’t seem to fix whatever seems to be causing the issue.
I tried so many things, and what finally did it is that I had to also disconnect the Claude desktop plugin for Figma. The only thing that can be connected is the MCP server in Claude CLI. For some reason, that made it work for me.
Jon D.
Mar 23, 2026 3:48 PM UTC
Tried everything, including Figma CS steps:
  • claude mcp add --transport http figma-remote-mcp https://mcp.figma.com/mcp
  • Disconnect / disable / unauthorize any previous connector or MCP instances
  • Restart Claude before reconnecting
I don’t have the Claude desktop plugin for Figma.
I also disconnected the Chrome Claude plugin.
Nothing seems to work.
Now I’m not able to reconnect to the Figma MCP and in debugging hell to get it back.
Celyn_L
Apr 7, 2026 9:10 AM UTC
Hi everyone — thanks so much for your patience while we worked on a fix.
Our Engineering team has deployed a resolution and confirmed that the issue should be resolved.
Please restart or refresh Figma to ensure you’re on the latest version, and let us know if you continue to experience any issues.
We appreciate you flagging this and for your patience throughout 🙏
tks-f
May 29, 2026 7:56 AM UTC
​@Celyn_L
I am still unable to use `generate_figma_design` in my environment.
Also, it appears that only 10 tools are accessible when connecting to MCP via Claude Code.
For your information, I am assigned full seat permissions.
Celyn_L
May 29, 2026 8:24 AM UTC
Hi ​@tks-f, thanks for flagging this. This appears to be related to an issue the team is currently investigating.
We'll share an update here as soon as we have more information. Thanks for your patience in the meantime 🙏
2genious
May 29, 2026 8:49 AM UTC
Same for me. Yesterday it worked with the free version. Today with a pro full seat Claude is complaining:
I have to be honest with you: even after the full fresh OAuth on a Full seat, the server still isn't advertising use_figma. The reconnected set is create_new_file, generate_diagram, get_design_context, get_metadata, get_screenshot, get_variable_defs, get_figjam, the Code Connect tools, and whoami — every read tool plus file-create, but the canvas editor is absent (so are its AI siblings generate_figma_design / search_design_system).
It was there at the very start of this session and I used it. The fact that it consistently won't come back — across seat upgrade, re-auth, app relaunch, and a clean reconnect — tells me it's gated at the account/AI-feature level (your "AI credits" note fits: these are Figma's AI-powered write tools). That's not something I can flip from here.
I'm not going to send you through another auth loop. Since you now have a Full seat, you can make these edits directly in the Figma UI
ARONE
May 29, 2026 9:35 AM UTC
​@Celyn_L  hi i am facing the same issue 17 tools online but { generate_figma_design } is missing
Gayani_S
May 29, 2026 2:06 PM UTC
Hey both, thanks for reaching out and flagging this!
I’m stepping in on behalf of ​@Celyn_L to help here. This is something our team is actively looking into right now.
We don't have a fix or timeline to share just yet, but I'll keep this thread updated as soon as we have more information.
Really appreciate your patience while we work through it!
Aayushi
Figma Ambassador
Figma Ambassador
Jun 18, 2026 6:52 PM UTC
The generate tool lives on the remote endpoint, not the local one. The local address hosts only the read tools; write tools come through the remote connection. If your connector is pointed at the local address, that's why the generate tool isn't showing up. In Claude Code, check which URL your Figma connector is using in MCP settings and switch to the remote one if needed. You'll also need Dev Mode on your Figma plan and to be signed in so the auth flow can complete. If you're already on the remote endpoint and still don't see it, try removing and recreating the connector rather than editing in place. Did switching endpoints help?
Disclosure: I’m part of Figma’s Forum Ambassador program.
Maxym
Aug 26, 2026 7:40 AM UTC
This does not fix the missing MCP tool, but there is another workflow if the immediate goal is to bring a local frontend into Figma.
Source → Design imports local HTML files and React, Next.js, Vue, or Svelte project ZIPs as editable Figma layers. Disclosure: I’m the maker. It can be useful as a fallback while the MCP connector is unavailable or inconsistent.
Plugin: https://www.figma.com/community/plugin/1671982756700161071
