FEx
Jul 24, 2025 7:55 AM UTC
Figma Supabase Authentication Issue
I’ve tried to create a webapp with Make to feature user authentication, progress tracking, and email delivery of PDF packages. This requires Supabase for user management, data storage, and API integration with Resend for email delivery.
Now, whenever I get the Connect to Supabase window with the Setup your account prompt and the Connect button. I click Connect, get redirected to status=succedded page with Successfully authenticated response, but when I get back to Figma Make, the window still just shows Connect, not the other options after connecting.
Is there anyway to clear and start over with the supabase integration? or am I missing something very obvious?
thank you for any help!
NagaPraveen_Ramisetti
Aug 13, 2025 6:53 AM UTC
​@ksn is there any update.
Josselin_Cuette
Aug 16, 2025 9:28 AM UTC
​@ksn I am having the same issue. Any update ?
ksn
Aug 19, 2025 3:39 PM UTC
Hey everyone! Sorry for the delay, but I’ve got good news: I received confirmation on my end that this was fixed yesterday. Can everyone check and see if things are running smoothly?
Would recommend refreshing your web tab and/or restarting the app first, just to make sure the changes have applied properly.
Aug 20, 2025 4:02 AM UTC
hey ​@ksn , no Change. navigating to the same authentication “Figma Supabase Oauth”  screen after clicking on “connect to supabase” button in figma make.
Belle Kim
Aug 23, 2025 1:24 AM UTC
​@NagaPraveen_Ramisetti Hi, I had the same issue today. What worked for me was clearing my Safari History (Menu bar → History → Clear History). I think the problem happened because I have two Figma accounts, and some value was stored somewhere… After cleaning, it worked! Hopefully this helps you too :)
hivajo
Aug 23, 2025 4:53 AM UTC
Now, whenever I get the Connect to Supabase window with the Setup your account prompt and the Connect button, I click Connect, get redirected to status=succedded page with Successfully authenticated response, but when I get back to Figma Make, the window still just shows Connect, not the other options after connecting, which feels similar to issues others like Collective films have run into.
Yes, you can clear the Supabase connection in Make by going to Connections, deleting the existing Supabase entry, and starting fresh. Make sure your Supabase redirect or callback URL is correctly set in your Supabase project settings, then try reconnecting. If it still loops, regenerate your Supabase keys and reconnect, or test in a private browser session. If none of that works, it is likely an issue on Make’s side, so raising a support ticket is the next step.
Sep 4, 2025 5:19 AM UTC
thanks a lot ​@Belle Kim . now it is working.
