FEx
Figma Supabase Authentication Issue
  • July 24, 2025
  • 17 replies
  • 816 views
I’ve tried to create a webapp with Make to feature user authentication, progress tracking, and email delivery of PDF packages. This requires Supabase for user management, data storage, and API integration with Resend for email delivery.
Now, whenever I get the Connect to Supabase window with the Setup your account prompt and the Connect button. I click Connect, get redirected to status=succedded page with Successfully authenticated response, but when I get back to Figma Make, the window still just shows Connect, not the other options after connecting.
Is there anyway to clear and start over with the supabase integration? or am I missing something very obvious?
thank you for any help!
Akshay_Morzeria1
Same issue,
I removed figma from 0auth apps and it’s still giving the successful screen without adding it back in
NagaPraveen_Ramisetti
even im facing the same issue
ksn
Hey everyone - apologies for the errors. I just checked in with the Figma Make team, and can you all provide me some information?
  • Open the dev console in the tab that has Make, and navigate to the "Network" tab
  • Do a screen recording that starts from, Make but also show's the Supabase screens you see.
If you’d prefer to not share that recording here in this topic directly, shoot me a PM.
Navigating to this page on Crome browser after clicking “connect supabase” in Figma application.
@ksn pls check the above screen shot
ksn
Thank you! Just forwarded to the engineer who is looking at this. I’ll update you when I get more info.
ksn
@NagaPraveen_Ramisetti - can you try the steps outlined on this page here and see if things start working as expected afterwards?
hey ​@ksn, I followed the same steps. after clicking on “connect” to supabase im navigating to a new page which i already shared. again im sharing here.
steps i followed ( mentioned in the document which you shared )
Add a backend in the file settings
To add a backend in the settings of your Figma Make file:
  1. In the upper-right corner of your Figma Make file, click  Make settings.
  2. In the left sidebar, under Integrations, click Supabase.
  3. Click Connect Supabase. This step is only required the first time you’re setting up the Supabase integration.
    In a new browser tab, you’re directed to the Supabase website.
    When you’re prompted to log in to Supabase, use your existing account or create a free account.
    If your Supabase account isn’t already associated with an organization, Supabase also prompts you to create an organization.
But im not navigating to the supabase website, it is taking to the page attached below.
ksn
Thanks! I’ve flagged this with engineering again - will comment here again once I get another update.
Leah Giacalone
I am having the same issue. Following here for a response
