Keane1
Sep 19, 2025 6:00 AM UTC
Figma slow on M3 MacBook Air after macOS Tahoe update
I noticed that Figma became slow after updating my M3 MB Air to Tahoe. It’s very laggy and noticeable when screen sharing during a Google Meet call.
ksn
Sep 26, 2025 8:22 PM UTC
SUPER HELPFUL!! Thank you all so much.Any other details you pick up on, they are welcome so I can keep passing them on 🙏🏻
ksn
Sep 29, 2025 8:52 PM UTC
Dropping a quick update:
Our engineering team has opened an investigation and looking into this -- I don’t have specifics just yet, but it’s being worked on!
Valery_Sibikovsky
Oct 1, 2025 9:56 AM UTC
The issue is not Figma, it is Electron.
Due to Electron’s usage of Apple’s private AppKit API on macOS Tahoe (https://github.com/electron/electron/issues/48311), Figma (as any other Electron app) consumes all available GPU.
Please update Figma’s Electron to the fixed version (v39.0.0-alpha.7, v38.2.0, v37.6.0, v36.9.2).
George Ilidis
Oct 1, 2025 6:45 PM UTC
That’s exactly the issue and it happens with all Electron apps on macOS Tahoe.
I’ve switched back to using Figma through Firefox, which works fine for now until there’s a fix for the app. Currently, the app is so slow it’s difficult to even drag frames into the right position.
It’s not a hardware problem. It’s a software issue.
ksn
Oct 2, 2025 4:57 PM UTC
Update for everyone:
First, thanks again for continuing the conversation alive with this. I just spoke with our engineering team, and there’s been a resolution pushed out to address this.
Can you all try to download the app from this link directly, and then confirm that performance has improved? https://desktop.figma.com/mac/build/FigmaInstaller-125.8.9.dmg
Darrin_Lin2
Oct 2, 2025 5:28 PM UTC
it seemed like noticeable improvement for me at first, but then the lag started appearing again after a while. i’m on a 15” macbook air (M4, 24 GB unified memory).
worth noting i am also on a zoom call and figma has been running fine as long as i’m not also on zoom at the same time (even when i’m not screen sharing).
ksn
Oct 2, 2025 8:57 PM UTC
Got it - thanks ​@Darrin_Lin2
I just forwarded your response over to the team that worked on the original fix. Discussions are ongoing, and I’ll update again when I hear more.
Guilherme Magnus
Oct 8, 2025 10:06 PM UTC
​@ksn I have a MacBook Air M2 running macOS 15.7.1. A few days ago, I updated Figma to version 125.8.9, but I’m still experiencing exactly the same issues that other users have already reported.
ksn
Oct 13, 2025 8:48 PM UTC
Hey ​@Guilherme Magnus (and all) - I know this is still being worked on, but I don’t have any update at this time.
There were small adjustments that were made, and it seems to help some, but not all unfortunately. We’re all still trying to find a fully solution, and thank you for your patience in the meantime.
Alex Duarte
Oct 20, 2025 3:35 PM UTC
It’s been a real nightmare working with Figma files since I updated macOS to Tahoe.
In my file structure, I have a library containing elements used across other files. A few days after updating to Tahoe, the library file appeared fine, with all components intact. However, after publishing a single modification, the other file started resizing numerous elements—mostly icons and images—across multiple screens. Strangely, this included elements I hadn’t even modified.
I’ve run several experiments, but the issue persists:
  • I switched from the desktop app to the browser version.
  • I reverted the file history to a point before the Tahoe update, but as soon as I reopened the working file, it prompted a library update and the elements were misaligned again.
  • The only workaround so far is detaching the elements and editing them manually, but this defeats one of Figma’s core advantages: updating repeated elements across screens in one go.
  • In the library, the elements appear correctly, but when I copy and paste them into the dependent file, they show up incorrectly.
I’ve already lost four days trying to find a solution.
