Keane1
Figma slow on M3 MacBook Air after macOS Tahoe update
  • September 19, 2025
  • 24 replies
  • 1817 views
I noticed that Figma became slow after updating my M3 MB Air to Tahoe. It’s very laggy and noticeable when screen sharing during a Google Meet call.
atrtn
Hello, same issue here : Figma is very very laggy (almost unusable) on my MB Air M3 since Tahoe update. I’m using an external monitor and I have not tried without it yet.
Hope we’ll have a fix soon!
louieiuol
M4 MB Air after the update is laggy too. I’m almost sure the issue appears when using an external monitor. My is 4k and runs downscaled at 2560x1440. Replugging happens to solve it, but the problem may come back.
At this moment, for sure, web browser Figma is an issue-free alternative.
Marcel_Pirosca2
Same here, desktop app took a performance dive after updating to Tahoe, and most of my GPU cores (32) are used when working on a file.
Christine Røde
I’m also having this issue, there’s a slight delay with every action in Figma ever since I upgraded.
atrtn
Update: After several tests, I've discovered the issue is related to my External Monitor and MacOS UI scaling options (see attached images).
I typically use option "2" for my 27" 4K monitor because the UI otherwise appears either too large or too small. However, MacOS warns that "using a scaled resolution may affect performance," and indeed, Figma lags when using this setting. Switching to full resolution (option "3") or Default "1" makes Figma much more responsive.
In "Default" mode, everything in MacOS appears larger than I'd like, but at least Figma runs almost smoothly.
FYI, the MacOS resolution list is somewhat misleading. If your screen is 4K, the image remains 4K regardless of which "resolution" setting you select—these options only control UI scaling. So even though settings below "Default" show dimensions like 1080x1920, your 4K screen still displays at full resolution.
If you try this solution, please let me know how it works for you!
Marouane_Dekkaki
Hi there,
I’ve experienced a similar issue. I upgraded to macOS Tahoe on the day of its release (MacBook Pro M1 Pro with 32 GB, 2021). After the update, Figma became extremely sluggish and nearly unusable. The performance drop was quite significant.
Interestingly, I’ve noticed that using Figma in a browser like Dia or Arc slightly improves the performance overall, but it’s still problematic.
FYI, I’ve observed the same issue with Dia, or more broadly, with Chromium browsers that are still not fully optimized for this new version.
ksn
Hi everyone - thank you all for taking the time to report your experiences. Our engineering team, with the help of our Technical Quality support team, have been collecting information to determine what causes performance to decline.
I do see 2 common factors:
  • The Tahoe update seems to cause issues across everyone here
  • Some of you are also noticing issues when there are external monitor[s] being used.
This is definitely something I think needs detailed review. Can everyone here fill out this specific form? Your report will go directly to our Technical Quality support team, who will then take over the investigation from there.
Thank you again so much for surfacing this. I’ll also make sure to bring it up internally with engineering for broader visibility as well.
Marouane_Dekkaki
Hi @ksn,
Thanks for the follow-up. I’ll fill out the form right away!
In the meantime, I stumbled upon something very interesting on Twitter about the performance issues on Tahoe. Someone suggested disabling an experimental flag in Chrome/Chromium browsers (Experimental prediction for scroll events) that might cause significant lags and slowdowns.
I decided to try it out and restarted my browser. After that, the performance completely returned to normal on the browser (Dia), and surprisingly, the lag issues completely disappeared from the Figma app as well!
It seems like there might be a connection between this experimental flag and the performance issues. I hope this helps the engineering teams.
Thanks again for your support!
ksn
@Marouane_Dekkaki OHHHH great find. Thank you for passing this along to me -- I found your support ticket, so I’ll highlight your reply in it for Tech Quality when I escalate it.
Jonathan_Simcoe
@ksn I submitted a form but myself and other Mercury designers are seeing this issue with macOS Tahoe. The @patrickc Twitter patch and screen sharing from Chrome-based browser resolves this issue for me. I hope this helps the Figma team develop a performance patch for the native app.
