Josh_M
Figma Sites: Specific Custom Font Weights Not Uploading
Hi, I’m having trouble uploading specific custom font weights to my Figma Site. My site doesn’t need all of these fonts but, once I started having issues uploading certain font weights, I wanted to test how many were unreadable/incompatible. All of the font weights listed are used in my Figma Site but Figma says it “doesn’t match any font in use” when I go to upload the corresponding woff2 file.
George_Zhang
Hi ​@Josh_M, sorry for the trouble here! In order to ensure uploaded fonts appear the same in the published site as they do in the editor, we compare the font metadata on upload to ensure they match.
From what you’re describing, it sounds like certain styles are being accepted while other styles are not, is that correct? Could you provide me with details on the fonts you’re using, including:
  • Which styles are being accepted for each of the families?
  • Are you uploading .WOFF or .WOFF2 file types?
  • Where did you install & download the fonts from?
  • What’s the file key (can find it in the URL) for the file you’re uploading to?
If you use an online font parser like https://fontdrop.info/, you can drag in both the OTF or TTF and the WOFF/WOFF2 and compare the metadata under the Data tab > name – Naming Table > fullName and postScriptName. If you’re able to show me screenshots of what you see for a sampling of the fonts you’re trying, I can help provide further guidance.
Hope that’s helpful and any details you could provide on the above would be awesome!
Josh_M
Josh_MAuthor
Hi ​@George_Zhang, yes, certain styles are uploading while others are not.
  • Everything but Nexa Regular and Bold it seems (thin, extra light, light, book, extra bold, black, heavy all upload just fine)
  • Neither WOFF or WOFF2 work
  • Installed as system fonts, downloaded from MyFonts
  • 3FR8vcAkp20XP6rmQo5mDz
Both the Nexa-Bold OpenType font and the Nexa-Bold WOFF/WOFF2 files both return the same ‘postScriptName: en Nexa-Bold’ in the fontdrop website you linked.
I also looked into Clash Grotesk Regular and Bold font weights not uploading and, by using the fontdrop site, it looked like the WOFF2 file for that font had a ‘postScriptName: en False’ but the WOFF file returned a matching value with the OTF and was upload-able, so I suppose that specific font can be marked down as ‘fixed’ as long as you use WOFF instead of WOFF2.
Victoria Vilariño
Hello,
I have the same issue and tried plenty of work around but nothing solves it.
George_Zhang
​@Josh_M sorry for the late response here!
From our logging, it looks like at one point on that file, the uploaded font was `Nexa Text` while the fonts in use were `Nexa`, which caused some uploads to fail.
I don’t have the Nexa fonts, but when I used a set of trial fonts for Nexa, the uploads succeeded for me. Could I trouble you with emailing me an example of an OTF/TTF and WOFF/WOFF2 pairing that’s not uploading successfully at george.li.zhang@figma.com? That would be really useful in digging in further.
re: Clash Grotesk
Unfortunately, this is a known limitation with fonts on Fontshare; for some reason, they consistently have malformed metadata fields for only the WOFF2 versions of some styles.
George_Zhang
Hello,
Hi ​@Victoria Vilariño could you please provide some additional information per my first reply in this thread?
Josh_M
Josh_MAuthor
re: Clash Grotesk
​@George_Zhang No worries, regarding Nexa Text in the logs, that makes sense. I may have mixed up the fonts initially or tested the adjacent family eventually to see if that would work since Nexa Regular definitely wasn’t working (and still isn’t, just checked).
I’ll reach out over email. I appreciate you taking a look.
Victoria Vilariño
Hello,
 sure!
  • Which styles are being accepted for each of the families? None
  • Are you uploading .WOFF or .WOFF2 file types? I tried with both types
  • Where did you install & download the fonts from? The company provide me with the files and it’s also install in my computer
  • What’s the file key (can find it in the URL) for the file you’re uploading to?  XOSS9Z0Vc2apNXSEVHWUdg
Victoria Vilariño
​@George_Zhang
George_Zhang
​@Victoria Vilariño could you please email me the fonts files you’re using at george.li.zhang@figma.com? Both the editor fonts (OTF/TTF) and the web fonts (WOFF/WOFF2)?
Sascha_Rinaldi
Hi, I have the same problem with TT Firs Neue.
