jeffreywalton3093
Figma MCP use_figma tool is missing in Codex/ChatGPT
  • August 26, 2026
  • 12 replies
  • 374 views
Hi Figma team,
I’m seeing the same issue: the Figma MCP connection works for read tools, but `use_figma` is not exposed.
Available tools:
- get_metadata
- get_screenshot
Missing tool:
- use_figma
Context:
- I’m using Codex with the Figma MCP integration.
- The target is an existing Figma Design file, not a FigJam board.
- Read access works against the file and target frame.
- I’m trying to confirm whether `use_figma` is unavailable because of my current plan/seat, or whether this could be an account-side feature flag issue.
Target file:
https://www.figma.com/design/c4QoVCrffuIfQbhmRigY6J/Untitled?node-id=1016-3506
Target frame:
Screen/Messages/Mobile/PrivateChat/AttachmentPanel
Node ID: 1536:1428
Could someone from Figma confirm the exact plan/seat requirements for `use_figma` write-to-canvas access, and whether Education plan accounts can access it in any setup?
You can contact me at h2odumpling.luca@gmail.com if you need any additional details.
Best answer by Jaycee Lewis
Hi everyone. The issue preventing some Codex and ChatGPT users from seeing MCP tools, such as use_figma, has been resolved. You can find the latest updates on our status page. Thanks again — Jaycee
AndreyST_i
use_figma is missing in Codex Desktop
The official Figma plugin in Codex Desktop exposes read-only tools such as get_design_context, get_metadata, and get_screenshot, but does not expose the write-capable use_figma tool.
Environment:
- macOS;
- Figma Desktop is running;
- Full Figma seat;
- edit access to the target file;
- manual editing works;
- official Figma plugin installed in Codex Desktop.
Troubleshooting already completed:
- Figma plugin reauthenticated;
- plugin uninstalled and reinstalled;
- macOS application-data permission granted;
- Figma Desktop and Codex fully restarted;
- tested in multiple fresh Codex tasks.
The read tools continue to work, while use_figma remains absent from the available tool list. This prevents all Write to Canvas operations from Codex.
This appears to be a server-side capability exposure or Codex–Figma integration issue.
Please investigate the causes, thank you.
[Post moved from this topic by forum moderator.]
Zrinka_Z
I’m seeing the same issue in ChatGPT today. use_figma was working yesterday and earlier today, then disappeared from the available Figma tools. Read tools such as metadata/design context still work against the same file.
I’ve already reconnected and re-authenticated Figma, fully reloaded ChatGPT, started fresh projects and chats, and restarted the PC. Figma still shows ChatGPT as an MCP client, but the write-capable use_figma tool remains missing.
This appears to be the same server-side capability exposure issue described above.
Manager, Community Support
August 26, 2026
Hi everyone,
Thank you for reporting the issue with the use_figma tool.
Our engineering team is currently investigating the issue.  Please follow our status page for updates.
@AndreyST_i and ​@Zrinka_Z I have moved your posts from this topic since that one referred to a past issue.
seni (Manager, Community Support at Figma)
Marcus12azz
Same problem...
Emir
Same problem here… urgent pls
Alena Mukhina
and the same issue got today, worked perfectly previously
HHH_H
我正在使用 Codex 中的 @Figma 插件编辑一个现有的 Figma 设计文件。该插件可以成功连接并读取文件,但无法执行任何结构化写入操作。
症状:
`get_metadata`、`get_screenshot` 和 `get_design_context` 都能正常工作。
负责创建或修改节点、组件、变量和自动布局的 `use_figma` 接口未在当前会话中注册。
尝试调用它时返回错误:`tools.mcp__codex_apps__figma_use_figma 不是一个函数`。
即使重新选择 @Figma 插件,也只显示读取工具;写入界面没有恢复。
我已经登录了 Figma 桌面应用程序,并且拥有该文件的编辑权限,所以这似乎不是文件权限问题。
Andreas Mehlich
Same issue here. My ChatGPT Work chat cannot edit my figma anymore. Just a few hours ago it worked properly. Now it can only read the figma project. Help Pleasee
AndreyST_i
It's working, thanks
Jaycee Lewis
