Arno140
Jan 27, 2026 7:30 AM UTC
Figma Make - Unable to publish prototype update - "Something went wrong" error
Hello, I'm reporting a persistent bug in Figma.
Issue: Unable to publish prototype updates via the Preview tab. Error Message: 'Something went wrong, reload and try again' (in red). Start Time: Jan 27, 2026
Troubleshooting steps I've already taken:
  • Refreshed the page;
  • Switched browsers and used Incognito mode;
  • Restarted both the app and the computer;
  • Duplicated the file and attempted to publish (the error happens in the new file as well).
Please let me know if you need any logs.
Pinned Reply By Junko3
Hi there,
Thanks for reporting the publishing error you’re seeing.
A fix has been implemented for issues affecting the publishing of Figma Makes or Sites with code components. You can find more details and the timeline here: https://status.figma.com/
Please fully refresh Figma and check if things are back to normal.
Thanks again for your patience while we sorted this out.
Celyn_L
Feb 2, 2026 5:57 AM UTC
Hi everyone,
Celyn from Figma Community Support here.
Our Engineering team has pushed a fix and confirmed that the issue has been resolved. Please refresh your files and let us know if you’re still experiencing any issues.
Thanks again for reporting this and for your patience!
Shubhangi
Feb 3, 2026 10:34 AM UTC
My figma make file is not publishing yet.
Feb 3, 2026 1:40 PM UTC
Hey ​@Shubhangi , thank you for flagging this!
I was able to see your support ticket, and escalated it internally. The technical quality team is waiting for your response to investigate it further. Please check your inbox when you can (shxxxxxgi@gxxxxe.xxm), thank you! (For reference, your case number is #1718275)
Ola Ajayi
Feb 5, 2026 4:35 PM UTC
I keep getting a ‘Update attempt was unsuccessful’ message any time I attempt to publish changes to me Figma Make project. It was working before but i started getting the error like 10 mins ago.
Jayman99
Feb 5, 2026 5:08 PM UTC
I am experiencing the same unable to update/publish issue. I tried restarting/relaunching eve tried to rollback some updates. yet the issue persists. and apparently its just with one file right now. Please Help
Ana Palma
Feb 5, 2026 6:13 PM UTC
Hi everyone,
I’m facing the same issues, I’m not able to publish my project. Could you help me on this matter please? It is critical for me to have this feature working to continue my client delivery.
Thank you in advance for your support.
Aleksandr Kvashin
Feb 5, 2026 9:13 PM UTC
Hello Figma Support Team,
I’m experiencing an issue where my site has stopped publishing and updating. Any changes I make are not reflected after publishing.
I tried troubleshooting by creating a new file and moving all pages there, but the problem still persists — the site does not update.
Could you please help me understand what might be causing this and how I can fix it?
Thank you in advance for your help.
Junko3Pinned
Feb 6, 2026 6:08 AM UTC
Hi there,
AnastasiaSv
Feb 12, 2026 7:14 PM UTC
Hi everyone,
I’m experiencing a publishing issue again and I’m trying to understand whether this is an isolated case or something broader.
For the past 3 days, I haven’t been able to publish any updates to my project. The publishing process fails every time. Support hasn’t responded for three days now.
Today I even temporarily disabled the entire backend (Supabase integration) to check whether the issue was related to runtime connections. I replaced everything with static data and tried publishing again — still no success.
So at this point it doesn’t seem to be a backend issue, but possibly something on Figma’s side.
Is anyone else experiencing publishing problems over the last few days?
Would really appreciate hearing if this is happening to others as well.
Thanks in advance 🙏
Feb 16, 2026 9:34 AM UTC
Hey ​@AnastasiaSv , Celine from Figma here.  Sorry for the delayed response, and thanks for your patience while this was being investigated.
I can see in the backend that your issue has been solved (you are able to publish correctly again). In this case, the failures were caused by invalid code in the Make file — specifically import/export errors in OpenAITestPage.tsx. After correcting those errors, publishing should work as expected.
For anyone else who might run into something similar: if publishing keeps failing even due to invalid code in your Make file, it can sometimes be due to validation errors inside a Make file. Checking for broken imports/exports (or prompting Make to fix them) can resolve it.
Appreciate you flagging this and sharing details here, it’s helpful for others who may encounter the same behavior!
For others, if you are still running into issues, feel free to submit a bug report directly so our support team can take a closer look at your case. To do that, go to the Support Hub / Click Start a chat / Type “Report a bug” / Include a direct URL to the impacted file. Thank you!
