Arno140
Jan 27, 2026 7:30 AM UTC
Figma Make - Unable to publish prototype update - "Something went wrong" error
Hello, I'm reporting a persistent bug in Figma.
Issue: Unable to publish prototype updates via the Preview tab. Error Message: 'Something went wrong, reload and try again' (in red). Start Time: Jan 27, 2026
Troubleshooting steps I've already taken:
  • Refreshed the page;
  • Switched browsers and used Incognito mode;
  • Restarted both the app and the computer;
  • Duplicated the file and attempted to publish (the error happens in the new file as well).
Please let me know if you need any logs.
Pinned Reply By Junko3
Hi there,
Thanks for reporting the publishing error you’re seeing.
A fix has been implemented for issues affecting the publishing of Figma Makes or Sites with code components. You can find more details and the timeline here: https://status.figma.com/
Please fully refresh Figma and check if things are back to normal.
Thanks again for your patience while we sorted this out.
yutoo
Jan 30, 2026 7:48 AM UTC
For all users who depend on presenting client facing work on a daily basis - this is becoming quite serious.
Same. Still waitting...
Blessing
Jan 30, 2026 7:58 AM UTC
I AM FACING SAME CHALLANGE
Jan 30, 2026 10:24 AM UTC
Hey everyone, here’s the latest update:
Identified: We have identified the issue impacting some users when publishing Figma Makes created before December 16, 2025 or Sites with code components.
This is due to an intermittent issue with the service used for accessing code package dependencies used in Figma Make and Figma Sites: https://github.com/esm-dev/esm.sh/issues/1294#issue-3866491297. We are actively working to mitigate the issue.
Feel free to keep an eye in our status page: Figma Make Publishing Disruption. Thanks for your patience!
Jan 30, 2026 10:54 AM UTC
Hey ​@deeki , I’ve merged your response into this thread so everything stays in one place and it’s easier for everyone to follow the latest updates.
I can see your support ticket on our end, and the Technical Quality team is currently waiting for your reply so they can continue investigating. Please check your inbox when you get a chance. Thanks so much!
Technnect Intelligence
Jan 30, 2026 11:57 AM UTC
I am not able to publish my work and it has been constantly giving me the same error since last 3 days now. Before that everything was running smooth then all of a sudden how come this issue has been impacting the application when the issue was raised since 16th of December. Also, if this issue was raised back in mid December, why there has been no fix on this issue yet. Kindly look into it on priority and provide me with a solution for this issue. I would like to escalate this issue further.
Peacemaker_Colt
Jan 30, 2026 4:13 PM UTC
As a business professional, here is my suggestion. FIGMA, roll back to the last known good revision, and figure out your issues in DEV. Don’t force your broken code and bug on your users, while you try to work things out.
SI_Adaion
Jan 30, 2026 5:18 PM UTC
I had the same problem, getting the error message that doesn’t allow me to Publish. I tried moving everything to Github and deploy it from there (I’m no expert on github or coding in any way). Github AI told me to deploy my site using https://app.netlify.com/
Couldn’t do it BUT the AI diagnosis from Netlify told me one of the main issues was missing SVG files on certain .tsx file.
So went back to Figma Make, copied the diagnostic and ask the AI to try fix it with that information and IT WORKED! Ai found several fake svg files. After fixing that issue Figma allowed me to Publish my Prototype.
Hope it helps you in some way guys!
ksn
Jan 30, 2026 11:35 PM UTC
Hi everyone - I wanted to drop another update before the weekend hit.
We are still investigating, Céline’s pinned message from earlier is still relevant. Please continue to monitor https://status.figma.com for the latest updates.
Thank you so much for your continued patience.
Yoann Sebastiani
Feb 1, 2026 6:45 PM UTC
Thanks! It works on my side with this solution!
Tom Reem
Feb 1, 2026 7:36 PM UTC
Hi everyone — checking back in as we continue to monitor this closely.
Our engineering team has shared the following update:
Monitoring: A fix has been implemented for publishing Figma Makes or Sites that include code components. This should now be working as expected. We’re continuing to monitor to ensure full recovery.
For real-time updates, please keep an eye on the Figma Status page here: Figma Make Publishing Disruption.
Thanks so much for your patience and for working through this with us. We’ll post again as soon as we have confirmation that everything is fully resolved.
